Page 6 of 6 1 2 3 4 5 6
Re: Extractors finally fitted with 2 1/4 " exhaust. [Re: rxinhed] #1105657 08/03/20 01:10 AM
4
4runnernomore Offline OP
Been a very long time in between posts. Not much to report. During the Christmas break fitted up the custom rock sliders to protect the sills finally after having them powder coated along with the bull bar and rear tyre carrier.
My youngest son uses the Sporty as his daily driver these days.
Will have to get the rear diff rebuilt soon as I have a wicked diff whine happening. Suspect the Ring and pinion is badly chipped from previous servicing finding a couple of broken teeth so have sourced another 5.38 replacement form Korea to go in. Also need to replace the gear lever bushes again as the shifter has gone quite sloppy again.
Cheers Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: Extractors finally fitted with 2 1/4 " exhaust. [Re: 4runnernomore] #1105663 08/03/20 11:59 AM
P
philipm3 Offline
Chris,
Who are you using for your current source for the 5.38 R&P?
Thanks, Philip
Philip P. Mueller III
Re: Extractors finally fitted with 2 1/4 " exhaust. [Re: 4runnernomore] #1105665 08/04/20 05:01 AM
4
Hi Philip,
Page 4 of the build thread.
Cheers, Chris
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.007s) Memory: 0.6022 MB (Peak: 0.6719 MB) Data Comp: Off Server Time: 2026-10-21 22:06:05 UTC
