6g72 Crank Sprocket stuck.Suggestion? #1058185 03/26/13 01:53 AM
mike71800b Offline OP
I'm working on a friends 89 raider and the timing sprocket is stuck on the crank nose. Shortblock is out and on the stand so we can get to it well. We've done the usual propane torch and 180deg apart wiggle with heat and light brass hammer blows until the seal started to smoke a bit. Searching for stuck sprocket showed some 6g72 car engines with tapped holes in the sprocket where we have none.. I'm trying to avoid tearing up the oilpump by prying and there isn't a lot of anything else to pry against. Someone know a trick before i fab a punching pattern to tap the face of this sprocket or just groove it and chisle split it?
Thanks guys !
Mike
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: 6g72 Crank Sprocket stuck.Suggestion? [Re: mike71800b] #1058186 03/26/13 02:03 AM
sasnydley Offline
I am not an expert, but I have taken a few off. One I ended up essentially breaking the sprocket. It will crumble pretty easy. I think I used a thin piece of steel behind a pry bar. Make sure you replace the crank seal when done. Luckily I had taken one off a junk car before I did this.
There may be some sort off puller assembly that you could rent at a parts store.
Re: 6g72 Crank Sprocket stuck.Suggestion? [Re: mike71800b] #1058187 03/26/13 02:04 AM
StockRaider Offline
I used a paint stir stick to put my flat head against so I could gently pry. I ruined a pump housing AND a timing sprocket because of frustration before. If you use a brass hammer and gentle pressure you can slowly work if off
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 6g72 Crank Sprocket stuck.Suggestion? [Re: StockRaider] #1058188 03/26/13 04:16 AM
mxmikie Offline
2 jaw puller or a bearing spliter
Re: 6g72 Crank Sprocket stuck.Suggestion? [Re: StockRaider] #1058189 03/26/13 06:11 AM
KrzyDav Offline
it's real easy to mess up and scratch crankshaft ,so careful.
Prying on the ger from behind will often snap the lip off the gear,,,nd damage oil pomp at same time.
I don't think a gear puller will work without damaging that gears lip either.
The FSM says to drill nd tap to use puller.
It's the same T gear s on Chryslers
dave h.
Re: 6g72 Crank Sprocket stuck.Suggestion? [Re: KrzyDav] #1058190 03/26/13 04:13 PM
"The FSM says to drill nd tap to use puller."
AAhhhhHHaaaH I got the feeling that was the route I would be taking, did the FSM mention reuse old one or replacement with new sprocket?
Thx Dav !
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: 6g72 Crank Sprocket stuck.Suggestion? [Re: mike71800b] #1058191 03/27/13 12:05 AM
KrzyDav Offline
replce it.
I don't think they re very expewnsive, like 25 buck from Korum Mitsu,,,,but probbly 100,000 bucks from your locl dodge deaaler.
THey re not lwys stuck on , so yrd run might be in order. Prt # might be in Spec. Prts Repos. in FAQs.
dave h.
Re: 6g72 Crank Sprocket stuck.Suggestion? [Re: KrzyDav] #1058192 03/27/13 12:23 AM
the sprocket is powdered metal, so drill it and split it to take it off. I drilled a hole in the front face and drove in a tapered punch until it split. not very expensive.
Re: 6g72 Crank Sprocket stuck.Suggestion? [Re: mike71800b] #1058193 03/27/13 02:41 AM
W
willwinchforfood Offline
Mousemilk, yes, mousemilk. Head to your local friendly aircraft mechanics hangar any get some.
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: 6g72 Crank Sprocket stuck.Suggestion? [Re: willwinchforfood] #1058194 03/28/13 02:17 AM
KrzyDav Offline
MD100568
like, $45
Korum Mitsu,,,
Mitsubishiparts.com
dave h.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6438 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-07-15 02:06:21 UTC
