87 Raider (the LandRaider) for sale whole, or will part out. #1058205 03/27/13 02:31 AM
LandRaider Offline OP
I spent this Saturday cleaning up my old garage area. I'm required to move all my tools and vehicles soon, so this truck has to go. If someone wants the motor, /trans/transfer case, I will part it all out.
Here is a quick run down of the specs that I can remember.
94 GMC truck 4.3 vortec TBI, 700r4 from a K5 Blazer, NP231 CHD(2 inch chain, 6 pinion planetary) from an S10 with a slip yoke eliminator. Both Driveshafts are Tom Woods, Rear is a CV style, and front is a 10 inch slip with 60 degree joints in it.
Heat and AC work. Heater blows fire out of it.. AC cools good for the truck being so un insulated. It has a new compressor on it, and needs to be charged with freon... I can take care of this with the buyer if he/she is interested.
I'd sell the motor Running with all EFI, and acessories all the way to the transfer case for $1800 (Including ac system!!!
Rear axle is a Montero Sport axle with factor air locker, and disk brakes. 4.636 gears in it. It had the spring perches cut, and rotated to point it up at the transfer case to be compatible with the CV style driveshaft.
If the motor sells, I'd sell the rear axle, and driveshaft for $600
IFS is gone, and replaced with a solid front. Front axle is a Dana 44 from a grand wagoneer. It's got Yukon 4.56 gears, Timken bearings, an Eaton E-locker, Chromoly axleshafts, and Superjoints. It should be indestructible. GM Steering box, F250 shock mounts.
If the motor sells, I'd sell the front axle, and (10 inch slip driveshaft for $1200
15X10 aluminum wheels with 36X13.50 Swamper TSLs
It's got a 2 inch hockey puck body lift.
Springs are 6 inch YJ Lift springs.
It has an Art Carr shifter for the transmission, and a custom built one for the transfer case.
Has a remote oil filter.. located in the engine compartment, and an oil cooler up front.
Has a sealed intake system, and a Safari snorkle.
ARB Bumper from a Gen2 Montero, and a warn 8000 lb winch.....I MAY keep this item for my diesel montero... undecided
Inside floor is Herculined, and the front section has carpet. Suspension seat on the drivers side.
Brakes take a lil getting used to... Corvette 50/50 master cylinder... Stops fine, but needs a bit more pedal pressure than a normal passenger car. The Ratio of master cylinder bore to piston bore does not match exactly right, but it was the closes I could get with a MC that bolted in.
Headliner is trying to fall down. The truck is kinda rusty, but not a rust bucket. Certainly fixable, but the availability of cheap rust free raiders... I'd just do a body swap on this frame if I wanted a badass pristine truck. BUT.... if you wheel it, it's gonna get banged up.
This truck drives down the road straight(steering wheel is cocked) and will do 70 mph on the interstate all day long with 35s. When I had pro comp X-terrains on it, I used it as a daily driver for over 2 years. The 36s on there now arent very conducive to this, but it still drives on the street just fine.
Truck has some quirks, but will make someone an awesome wheeler, and great truck overall.
I JUST put in a new battery saturday, and filled it up with fuel. I'll sell the entire truck for $3500 <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 87 Raider (the LandRaider) for sale whole, or will part out. [Re: LandRaider] #1058206 03/29/13 12:30 AM
Anyone interested? Make an offer. Worst I can say is no.
Re: 87 Raider (the LandRaider) for sale whole, or will part out. [Re: LandRaider] #1058207 04/03/13 04:04 AM
Somebody get on this...!!!
Re: 87 Raider (the LandRaider) for sale whole, or will part out. [Re: MontyMcV] #1058208 04/04/13 01:04 AM
Yup, no money, don't have time to get mine running, too far away...blah blah blah.
I would have it, then it would sit. Curious if you've put this on Pirate, IH8Mud, Expedition Portal, even Ramcharger Central?
Re: 87 Raider (the LandRaider) for sale whole, or will part out. [Re: rxinhed] #1058209 04/04/13 07:44 PM
No none of those places.
Re: 87 Raider (the LandRaider) for sale whole, or will part out. [Re: LandRaider] #1058210 04/04/13 11:45 PM
More exposure may relieve you of the LandRaider, and fill your wallet.
Re: 87 Raider (the LandRaider) for sale whole, or will part out. [Re: LandRaider] #1058211 04/12/13 04:05 AM
xFezx Offline
I'd like to see this in person, but pictures will do for now. I looked a Polaris Ranger today but this looks to be alot cheaper.
You can call me Fez
'95 SR 15x8 steel rims w/ 33x12.5 Duratracs, cranked torsion bars, "Baja" lights
'09 Nissan Sentra SR
Re: 87 Raider (the LandRaider) for sale whole, or will part out. [Re: xFezx] #1058212 04/14/13 10:30 PM
Plus you can put this on the interstate, and go cross country.
Re: 87 Raider (the LandRaider) for sale whole, or will part out. [Re: LandRaider] #1058213 04/15/13 06:48 PM
Re: 87 Raider (the LandRaider) for sale whole, or will part out. [Re: LandRaider] #1058214 05/23/14 02:57 AM
Picking it up June 7th, 2014
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6477 MB (Peak: 0.7714 MB) Data Comp: Off Server Time: 2026-07-09 14:12:29 UTC
