MAF type 94 SR?
#1058329
03/31/13 06:45 PM
SO got a can of MAF cleaner, CRC brand, and on there is says dont use on Karman-Vortex MAF, and not to use on Mitsubishi's. SO the question is, Does anyone know if my montero SR has a Karman vortex MAF
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank. 93 600 Katana. stage 1 jet kit, Uni foam air filter 02 honda shadow. "for when the woman wants to go with" 97 Acura Integra.
Re: MAF type 94 SR?
[Re: mynion]
#1058330
03/31/13 07:50 PM
The Gen I Montero MAF Sensor has some cardboard stuff in it. That may be why you can't use cleaners. I have never looked at the Gen II MAF in my 95. Your idle mis issues Especially when cold are probably linked to the extremely complicated almost impossible to seal or keep sealed intake on these Butterfly DOHC engines. Also the idle control motor goes bad on the throttle body and idle won't kick up right when cold starting.
Re: MAF type 94 SR?
[Re: sasnydley]
#1058331
03/31/13 08:44 PM
Hum, I sprayed starter fluid all around the flutterby valve's/ intake manafold and didnt get any idle spikes... I know thats not 100% but...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5918 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-07-13 10:57:18 UTCValid HTML 5 and Valid CSS
