Driver side mirror #1058596 04/08/13 08:04 PM
Y
yotadiehard Offline OP
Is there a way to tighten a driver side mirror on a 1988 4wd pickup?
Re: Driver side mirror [Re: yotadiehard] #1058597 04/10/13 05:12 AM
kewlynx Offline
My FSM shows everything BUT that. I did get a replacement mirror for my 86; you have a set of screws under the finish cover (triangular piece). Might see if you can get a small screwdriver under it to pry off; just make sure the base where the mirror swivels isn't the culprit, vs the base itself being loose.
**Do** take your time.
Wouldn't hurt to have some loctite handy.
**ubi apis- ibi salus**
Re: Driver side mirror [Re: yotadiehard] #1058598 04/10/13 02:19 PM
G
Greg_Canada Offline
Depends on the mirror style, but i was able to adjust mine on my 89'. there is a nut that you can tighten under the plastic cover that kewlynx mentioned... you just have to carefully pry it off...
89 4Runner
Re: Driver side mirror [Re: Greg_Canada] #1058599 04/10/13 05:37 PM
Y
Popped off the plastic cover, plastic tube with a slit in cased around rod. I could see washer in the slit. I wasn't smart enough to take picture.
THe only thing that was accessible was the phillips screws holding it on the door.
Re: Driver side mirror [Re: yotadiehard] #1058600 04/10/13 09:13 PM
G
Greg_Canada Offline
remove the mirror from the door. there should be 2 or 3 screws? You will get to the bolt on the back side of the mirror. Sorry it's been 8 years!
89 4Runner
Re: Driver side mirror [Re: Greg_Canada] #1058601 04/11/13 10:24 PM
Y
Does it require going into the door panel?
Re: Driver side mirror [Re: yotadiehard] #1058602 04/12/13 02:16 PM
G
Greg_Canada Offline
If it's the mirror i'm thinking of, no it's all done from outside.
89 4Runner
Re: Driver side mirror [Re: yotadiehard] #1058603 04/15/13 04:21 AM
kewlynx Offline
Picture would be a big help, if possible. Click on the FAQ above to show yourself how.
Re: Driver side mirror [Re: kewlynx] #1058604 04/17/13 05:56 PM
4Crawler Offline
My '85 did not have OEM mirrors on it when I bought it. But on other vehicles, I have found there is usually an adjustment nut accessed from the base of the mirror to tighten them up.
Re: Driver side mirror [Re: kewlynx] #1058605 04/17/13 07:31 PM
G
Greg_Canada Offline
If they are these mirrors:
You take off the cap, unscrew the mirror, then you can adjust it.
89 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6384 MB (Peak: 0.7410 MB) Data Comp: Off Server Time: 2026-05-29 14:42:43 UTC
