blown head gasket #1058691 04/10/13 04:00 PM
bingocouple Offline OP
Does anyone know the torque sequence of the head bolts? I cant find it on my online manual.
Also, has anyone tried the blue devil head gasket sealer?
Re: blown head gasket [Re: bingocouple] #1058692 04/15/13 04:00 AM
Everet Offline
You need to tighten them in 3 step sequence and you should use new bolts because they are torque to yield bolts.
Bolts are to be torqued to 62 foot pounds so I would torque them to 20 ft/lbs on the first step, 40 ft/lbs on the second step and 62 ft/lbs on the last step making sure you follow the tightening sequence on each step.
Hope this helps.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5885 MB (Peak: 0.6362 MB) Data Comp: Off Server Time: 2026-05-29 22:35:00 UTC
