Has Anyone Ever Experienced... Seatbelt light on after running the battery down? #1058931 04/16/13 02:19 AM
MrJeebs Offline OP
... accidentally leaving the lights on and killing the battery to the point where one of the fuses starts clicking, at which point you realize you left the lights on and that the battery is dead. So you jump the truck only to discover that the seat belt light is now on permanently?
This happened to me this evening, and it was only for the fact that it is garbage night, and that as I walked past the truck I heard a clicking sound.
Any ideas why the seat belt light would be permanently lit now? Or is there something I can do to reset it?
This is in my 94 SR 6G74.
As always, thanks in advance for any and all suggestions.
Re: Has Anyone Ever Experienced... [Re: MrJeebs] #1058932 04/16/13 03:23 AM
As the voltage drops in the discharging battery, the amperage goes up. It may have fried the seatbelt light switch.
Or do you have a weight in the passenger front seat, triggering the light circuit?
Re: Has Anyone Ever Experienced... [Re: fasteddy] #1058933 04/16/13 03:35 AM
MrJeebs Offline OP
Hi Eddy,
Thanks for the reply.
No, there is nothing in the front seat. What a bummer.
I cant find the seat belt switch in ASA. Any idea where it is (in the seat somewhere I assume?) and if it can be replaced cheaply?
Re: Has Anyone Ever Experienced... [Re: MrJeebs] #1058934 04/17/13 12:30 AM
KrzyDav Offline
there might also be a diode involved. There are 2 taped in the the wires behind the gen 1 instrument cluster, don't recall right now what they go to. Don't know if they can burn out with continuity.
I cut the wire on my seatbelt. Might not get away with that on the more sophisticated SR.
dave h.
Re: Has Anyone Ever Experienced... [Re: KrzyDav] #1058935 04/29/13 04:19 AM
MrJeebs Offline OP
Thanks Dave,
I will have another look for the sensors, as I didn't see them first time around.
I appreciate the reply.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Has Anyone Ever Experienced... [Re: MrJeebs] #1058936 05/01/13 01:13 AM
plh Offline
If you find the issue, let me know please. I did the same thing (lights on - dead battery) last Thursday and also have the "fasten seatbelt" light on all the time now.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Has Anyone Ever Experienced... [Re: plh] #1058937 05/01/13 02:03 PM
DuCal Offline
I had this problem concerning the seat-belt light when I first got my 90. It had a Cobra security system. I pulled it out (Harder then it looked). The battery died that night due to a cutoff that was pulling power. After a jump and 30 min tracking the cut-off my seat-belt light stayed on. Mine was caused by the cut-off being routed to the seat-belt supply and when the batt died it somehow left that light on. I accidentally fixed it by replacing the driver wire all the way to the dash. So the diode answer may be the correct one. After rereading my post..... I may not have contributed much to the conversation. sorry, I tend to ramble. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Seattle WA... (Everett)
1990 Montero LS OME complete, 2"BL,spray-paint.
1990 Montero LS in the 1st stage of rebuild.
2009 Pilot, Bone stock.
"Let me put on my slightly larger glasses".
Re: Has Anyone Ever Experienced... Seatbelt light on after running the battery down? [Re: MrJeebs] #1058938 05/03/13 05:49 PM
Russya Offline
Happened to me once just like you. I disconnected my battery for a little bit an reconnected it and it went away. This was on my 98 gen 2.5. I think it only happens with jump starting the car since that's when it happened to me.
Re: Has Anyone Ever Experienced... Seatbelt light on after running the battery down? [Re: Russya] #1058939 05/05/13 04:39 PM
MrJeebs Offline OP
Ding ding ding! You sir, get the prize! I did as you suggested and disconnected the battery, left it off over night, and when I re connected it this morning, seat belt light was off!
Thank you for your replies, gentlemen. Much appreciated as always.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6257 MB (Peak: 0.7299 MB) Data Comp: Off Server Time: 2026-07-14 19:19:11 UTC
