Camshaft Sprocket Issue!!!
#1058940
04/16/13 03:34 AM
I have been trying to get my 89 Gen 1 V6 running and keep running into problems. Now the left side camshaft sprocket has alot of play in it. I took it off and the recess that the camshaft goes into is 1/16" of an inch too big. The camshaft end measures 1 1/4" the recess in the sprocket measures 1 5/16", Does anyone have a spare sprocket they could measure to see if the shaft I have is incorrect, it was changed, or if I need a new sprocket. Any help is appreciated, any suggestions for my situation will also be appreciated. Thanks
Chris Mink 1989 Mistubishi Montero 3.0 1998 Land Rover Discovery 4.0
Re: Camshaft Sprocket Issue!!!
[Re: MinksMontero]
#1058941
04/16/13 04:26 AM
Camshaft sprockets aren't too expensive. Buy another and be done. They are a wear part anyway.
[Re: rxinhed]
#1058942
04/16/13 05:31 PM
Thanks, yeah after closer inspection it was worn and it actually wore out 1/16"
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5922 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-06-17 13:27:37 UTCValid HTML 5 and Valid CSS
