Oil pump change possible when doing timing belt? #1059039 04/18/13 03:09 PM
Mike_Pirie Offline OP
Hi All,
I can't find a definite answer on this, and it's been awhile since I last replaced the timing belt.
Is the oil pump accessible/possible to change without removing the oil pan, raising the engine, etc. (3.0 engine)
At 250K original miles, my oil pressure is getting lower by the minute, and am hoping I can do something about it without a major repair.
Thanks
1992 montero, cranked t-bars, OME springs, 1-1/2" spring spacers, Homemade rear bumper and roof rack, 33" BFG AT, 1" body lift, Superwinch hubs, '95 SR locking rear axle, was AT - now V5MT1-3 5spd.
Re: Oil pump change possible when doing timing belt? [Re: Mike_Pirie] #1059040 04/19/13 03:05 AM
Not sure on the 12V SOHC, but the 24V needs the oil pan dropped.
Re: Oil pump change possible when doing timing belt? [Re: Mike_Pirie] #1059041 04/19/13 04:55 AM
KrzyDav Offline
Nope,
to unbolt the pickup tube you have to drop the pan.
to drop the pan you have to raise the engine and rotate front diff. <img src="/forums/images/graemlins/scared.gif" alt="" />
dave h.
Re: Oil pump change possible when doing timing belt? [Re: Mike_Pirie] #1059042 04/19/13 05:54 AM
geocrasher Offline
Are you sure that the oil pump is the reason for the pressure drop? There are a lot of reasons for pressure drop such as worn bearings etc.
http://tidbitsfortechs.com/
Re: Oil pump change possible when doing timing belt? [Re: geocrasher] #1059043 04/19/13 01:30 PM
Thanks guys.
The low presure is probably from a combination of things. On cold start-up, the pressure gets up to 70psi, but when warm the pressure is 30 at 3000rpm, and 20 at idle.
Looks like an overhaul is in the cards in the next year or two...
Re: Oil pump change possible when doing timing belt? [Re: Mike_Pirie] #1059044 04/21/13 03:30 AM
KrzyDav Offline
what kinda gauge are you using?
A 3.0 warm only runs about 10 lbs. at idle, around 700 rpm.
I run 80 lbs at cold start/idle,,,like 1,400 rpm.
Running around town - 40-60 lbs.
I have a very accurate autometer mechanical gauge.
I added an idiot light with a 20 lb switch. I get the red light when I sit at a red light. I'm not worried.
The electric gauge on your dash is very slow to respond and is not very accurate.
( just noticed,,,V5MT1-3 coversion,,, <img src="/forums/images/graemlins/kewl.gif" alt="" />)
dave h.
Re: Oil pump change possible when doing timing belt? [Re: Mike_Pirie] #1059045 04/21/13 12:24 PM
P
pcc Offline
The pressure looks pretty much OK. The 70 psi cold looks high depending on ambient/oil grade, the hot 30 at 3K is about where mine runs and the 20 at idle looks high, mine runs about 10 psi.
Maybe you want to attach an alternate gauge to see what it shows. What grade oil you running?
Re: Oil pump change possible when doing timing belt? [Re: pcc] #1059046 04/22/13 12:05 AM
Just put in a cheapo mech gave from autozone, because my dummy light was blinking sometimes at idle. So maybe I'm ok. I'll look for a better gage. And yes, I love the 5-speed.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6220 MB (Peak: 0.7208 MB) Data Comp: Off Server Time: 2026-07-17 06:40:52 UTC
