Fuel tank cleaning #1059260 04/28/13 03:35 AM
ryany Offline OP
I'm trying to get an ATV running that was left sitting for a number of years. The fuel in the tank appears to have dissolved the plastic filter sock and left a slimy mess in the bottom of the tank. Does anyone have any experience with some sort of solvent that will clean the sludge from the bottom of the plastic gas tank?
This is what I scraped out of the tank.
95 Montero SR
Re: Fuel tank cleaning [Re: ryany] #1059261 04/28/13 03:58 AM
hochkis Offline
I've never seen it that bad, but i have had good luck with berryman chem dip on old carbs and fuel tanks. You can buy it in gallons at most auto parts stores.
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: Fuel tank cleaning [Re: hochkis] #1059262 04/28/13 04:46 AM
socalmonty Offline
You're gonna want to be sure you get it all...how much cost/effort would it be to get another tank all together? Might be easier if it's an option. <img src="/forums/images/graemlins/confused.gif" alt="" />
Sean - Orange County, CA
MAIL: seanwilliams78@gmail.com
1995 Montero SR - For exploring and getting away!
1994 Volvo 850 Turbo - 402hp and counting!
1966 VW Bug 2275cc - For stoplight drags!
Re: Fuel tank cleaning [Re: socalmonty] #1059263 04/28/13 06:28 AM
ryany Offline OP
The tank is only sold as an assembly with the fuel pump and sending unit assembly included, for a measly $600. <img src="/forums/images/graemlins/scared.gif" alt="" /> I've already found a new pump and pickup filter for it for less than $100. I was actually able to get most of the goop out of the tank - it's in a small area at the very bottom about 8" x 4" - and I've got some Berryman's parts cleaner solvent in it now to loosen up the sludge.
95 Montero SR
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6055 MB (Peak: 0.6611 MB) Data Comp: Off Server Time: 2026-05-25 15:01:12 UTC
