Needed Badly: '94-'98 SR Oil Cooler #1059290 04/29/13 01:14 AM
MrJeebs Offline OP
The oil cooler in my SR is cracked at the fittings and is leaking profusely. I am looking for the cooler, bracket, stay, gaskets and bolts.
Please pm if you have available.
Thanks in advance!
Re: Needed Badly: '94-'98 SR Oil Cooler [Re: MrJeebs] #1059291 04/30/13 04:58 AM
KrzyDav Offline
untill you get what you need, you can disconnect the hoses at the engine and screw in some oil pan plugs(that's how mine is , temporarily), I think they are 16mm.
If you find one in a salvage yard make sure it's not off a C4C.
dave h.
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.5875 MB (Peak: 0.6348 MB) Data Comp: Off Server Time: 2026-07-15 00:21:31 UTC
