ECU 90 Montero 3.0 V6 *DELETED* #1059330 05/01/13 01:44 AM
DuCal Offline OP
Post deleted by DuCal
Seattle WA... (Everett)
1990 Montero LS OME complete, 2"BL,spray-paint.
1990 Montero LS in the 1st stage of rebuild.
2009 Pilot, Bone stock.
"Let me put on my slightly larger glasses".
Re: ECU 90 Montero 3.0 V6 [Re: DuCal] #1059331 05/01/13 02:13 AM
DuCal Offline OP
This will blow your mind. I am out front pulling the ECU, dude walks up asks if its burned. I say yup, (just a little frustrated). He knocks on my screen about 10 mins ago with an ECU in hand and says "Merry Christmas". I just about cried!............ In a totally manly way, of coarse. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: ECU 90 Montero 3.0 V6 [Re: DuCal] #1059332 05/01/13 03:20 PM
JAVYPRO Offline
Be careful you might have a bad TPS and that is known to burn an IC in the computer. Installing the new one without replacing the TPS might have the same consequences.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: ECU 90 Montero 3.0 V6 [Re: JAVYPRO] #1059333 05/02/13 02:18 AM
DuCal Offline OP
Thanks for the heads up
Re: ECU 90 Montero 3.0 V6 [Re: DuCal] #1059334 05/02/13 03:46 AM
KrzyDav Offline
I think it's the idle control servo that shorts out when it's disolved with solvent and burns out the ECU.
dave h.
Re: ECU 90 Montero 3.0 V6 [Re: JAVYPRO] #1059335 05/02/13 04:15 AM
Correct...
Not so much. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> ;-)
Seriously though... Also read its the ISC that can take out an ECU on one of the ecu repair websites
Re: ECU 90 Montero 3.0 V6 [Re: off-roader] #1059336 05/02/13 10:02 PM
DuCal Offline OP
Idle control servo?, is that the same as the idle air controller? Never herd of and ICS.
If its the IAC then that would make sense.... Cuz I just replaced it... It was FUBAR.
Re: ECU 90 Montero 3.0 V6 [Re: DuCal] #1059337 05/02/13 10:37 PM
There are many names because there isn't an industry standard one so different manufacturers call it different things.
Idle Speed Controller = Idle Air Controller = ISC/ICS = IAC
HTH... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: ECU 90 Montero 3.0 V6 [Re: off-roader] #1059338 05/02/13 11:04 PM
DuCal Offline OP
Yah, Idle was off, replaced IAC, then stuff went haywire found bad ECU. So, I'll put in this new ECU and should correct the issues. Thank you all for the help. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: ECU 90 Montero 3.0 V6 [Re: DuCal] #1059339 05/02/13 11:17 PM
Before you replace the new ECU confirm the IAC is still good. The ECU repair places mentioned that a bad ecu can make the IAC go bad and vice versa.
The procedure to check the IAC is in the FSM. I don't have access to mine right or I'd post the process here.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6422 MB (Peak: 0.7672 MB) Data Comp: Off Server Time: 2026-06-07 07:29:16 UTC
