Page 2 of 3 1 2 3
Re: Should I buy this Dodge Raider!? HELP [Re: mfarmer10] #1059396 05/06/13 07:26 PM
Can check the radiator fluid and motor oil condition. Don't recall what the coolant change is (if there's oil in it) but the motor oil will be a chocolate brown if the coolant is in it.
Alternatively any trained mechanics can run a test to check for issues. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Should I buy this Dodge Raider!? HELP [Re: off-roader] #1059397 05/07/13 03:18 AM
mfarmer10 Offline OP
I'm really eager to learn how to work on cars, would you say a raider is a good place to start? Would the 4 cyl be easier to understand than a v6?
Re: Should I buy this Dodge Raider!? HELP [Re: mfarmer10] #1059398 05/07/13 04:27 AM
KrzyDav Offline
I learned alittle wrenching in my early years, but since gioning the WIRE in '03 I've earned my mastersdegree on here from folks on here helping me.
The V6 is less complicated for a beginner than the 4.
I personally like inline engine better than a V cause I can see everything better and it's easier on an ageing back,,,
but,,,,
The 4 clys have a carb with all the emmission hoses and gizmos that goes with that.
Fuel Injection system reduces the number of vacuum hoses and gizmos for emissions control because its computer controled. The copmuter systems on pre 1995 are pretty simple, too.
The Transmission with the V6 (esp. the manual) are way more H.D. than the 4 clys.
The axles and diffs are alittle more H.D. too.
This vehicle or a Toyota pickup with a 4 cyl 22R fuel injected are the best for a beginner to own IMHO,,,both also the best for a vehicle that can be kept in the family forever and handed down thru the generations. I've had mine since '96.
2 door Raider is a Short Wheel Base. SWB offroad vehicles are getting rare therefor more collectable (like old jeeps and old landrover,,,but Raiders don't break down constantly),and are better offroad.
Re: Should I buy this Dodge Raider!? HELP [Re: KrzyDav] #1059399 05/07/13 04:42 AM
ryany Offline
Additionally, the V6 will ride much better since it has a coil-sprung rear axle rather than the leaf-spring rear suspension that came on the 4-cylinder models.
95 Montero SR
Re: Should I buy this Dodge Raider!? HELP [Re: ryany] #1059400 05/07/13 12:48 PM
RECON45 Offline
v6 is easier to work on not having to mess with carb. Also around here that 4 cylinder will get bog down and you will wish you had the extra power. Not saying the v6 has a ton of power. Not to mention with the v6 models you get a little bit beefier suspension and axle parts. There is a few of us Carolina peeps if you need a hand give us a buzz. I do not think it is to bad. Drive it. It will tell you if there is something wrong.
Re: Should I buy this Dodge Raider!? HELP [Re: RECON45] #1059401 05/07/13 01:08 PM
bearingman Offline
I'm less than an hour from you-I have the same vehicle except mine is Montero
if I had the $$$ I would buy it just for parts
Re: Should I buy this Dodge Raider!? HELP [Re: mfarmer10] #1059402 05/07/13 11:54 PM
plh Offline
Wow, looks good. Did you buy it?
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Should I buy this Dodge Raider!? HELP [Re: mfarmer10] #1059403 05/08/13 02:39 PM
cdl1701 Offline
Black is like an oven during the summer if the AC stops working... <img src="/forums/images/graemlins/scared.gif" alt="" /> is what I looked like last summer in mine.
I wonder what the interior looks like.
88 Montero, 2.6 Black
Re: Should I buy this Dodge Raider!? HELP [Re: cdl1701] #1059404 05/08/13 03:57 PM
Hahah the interior is tan, maybe that would help? I'm trying to go look at it this weekend, it's 3.5 hours away so it's a bit of a haul. Anyone live coveniently in York, Sc? Haha. How long can it be driven with crispy valve seals?
Re: Should I buy this Dodge Raider!? HELP [Re: mfarmer10] #1059405 05/08/13 04:18 PM
RobCambo Offline
That's a good looking truck. Best of luck with it.
1986 Pajero 2.6l 5spd manual SWB
http://s690.photobucket.com/albums/vv265/RobCambo/
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6409 MB (Peak: 0.7664 MB) Data Comp: Off Server Time: 2026-07-15 02:38:22 UTC
