what amp fuse #1059647 05/13/13 04:51 PM
bearingman Offline OP
I need to know what size fuse I need for battery terminal--there is a "block" on one of my battery cables that has 3 fuses in it. I need to know what amperage they are and what they are for? I have 3.0, 1989. Thanks.
Gary
Re: what amp fuse [Re: bearingman] #1059648 05/13/13 06:22 PM
Not sure of the top of my head nor can I look it up right now but you should be able to look it up in the factory service manual or your owners manual...
Re: what amp fuse [Re: off-roader] #1059649 05/13/13 09:55 PM
KrzyDav Offline
that's a 100 amp. White wires coming off that one.
You need to remove the bolts inside the little box to change it.
dave h.
Re: what amp fuse [Re: KrzyDav] #1059650 05/13/13 10:13 PM
Dave IIRC the 3 fusible links are not all the same so that's why I'm suggesting checking it in the FSM unless somebody can tell him the correct value for each. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: what amp fuse [Re: bearingman] #1059651 05/13/13 11:18 PM
cheesegrater Offline
My '89 3.0 MT says, left to right, ALT-100, HEADLP-40, MPI-30.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6064 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-07-14 10:49:49 UTC
