Gen 2/2.5 rear speaker removal.
#1059691
05/14/13 09:11 PM
I want to replace the rear set of speakers in my 99. Looks like I have to pull the entire interior panel to get at them? is there a trick to it I'm not seeing?
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
Re: Gen 2/2.5 rear speaker removal.
[Re: justice]
#1059692
05/14/13 09:45 PM
Correct. It's easier than it sounds, however. Get a set of Harbor Freight trim panel removal tools for $8, remove the screwed-in trim and start popping loose the panels. It only takes a few minutes, really.
[Re: JohnnyBfromPeoria]
#1059693
05/15/13 09:56 PM
If you've got 3rd row seats they'll have to come out also, along with the seatbelt mounting points. The trim around the windows has to be pulled loose at the bottom also, as well as the rear cargo door threshold trim plate. It's tedious - just when you think you've got the trim panel off there's something else to remove.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: ryany]
#1059694
05/16/13 02:48 PM
Thanks. I need to take the 3rd row seats out anyways. so I'll kill a couple birds with one stone here. Also, do you know what size they are (the speakers)?
[Re: justice]
#1059695
05/16/13 03:22 PM
98 Montero, 184k.
[Re: justice]
#1059696
05/16/13 03:24 PM
The rears are 6x9, I believe. NVM, Got beat to it <img src="/forums/images/graemlins/lol.gif" alt="" />
1994 Mitsubishi Montero LS, Stock (for now) General class license -KF5UHG
