what should I replace after top end off***names of all heater hoses? #1059697 05/15/13 06:10 AM
cjsmontero Offline OP
Heads going back on this week, timing belt, water pump, tensioner, injector o rings, idler pulleys, all belts, upper and lower rad hoses, bipass hose. Anything Im missing while top end is off? Also can anyone give me all correct names of the already molded heater hoses? Thanks
85 Dodge D50, 90 Montero, 05 durango
Re: what should I replace after top end off [Re: cjsmontero] #1059698 05/15/13 08:00 AM
On what?
Re: what should I replace after top end off [Re: JohnnyBfromPeoria] #1059699 05/15/13 09:23 AM
I'd assume his v6 since the d50 probably has a 2.6 with the timing chain? That's my guess anyway...
Re: what should I replace after top end off [Re: off-roader] #1059700 05/15/13 03:50 PM
Are you going to replace the camshaft seals? If so, you'll need a new set of valve cover gaskets. And if you take the valve covers off, why not replace the valve stem seals?
Re: what should I replace after top end off [Re: JohnnyBfromPeoria] #1059701 05/15/13 04:38 PM
Geez I screwed that up. Its th 3.0, I have the whole felpro gasket set already, shop put the stem seals on, I have cam plugs. Mainly what hoses should I buy....or do you reccomend changing. Or anything else for that matter. I have tensioner, but not spring. Nobody seems to have it. I need it pretty quick, hes working on it all week. Thanks guys, again, apologies for not saying what it is.
Re: what should I replace after top end off [Re: cjsmontero] #1059702 05/16/13 02:02 AM
KrzyDav Offline
replace those knuckle busting trottle body hoses. 9.5mm or 3/8" heater hoses.
Make sure that threadlock was used between the cam caps and head (metal to metal surface) 'cause that tiny seam will give a very messy oil leak.
O ring on distribe shafe,,,O ring between distib mount body and front of head.
Re: what should I replace after top end off [Re: KrzyDav] #1059703 05/18/13 07:13 AM
bump <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: what should I replace after top end off***names of all heater hoses? [Re: cjsmontero] #1059704 05/18/13 09:39 AM
Crank bolt. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: what should I replace after top end off***names of all heater hoses? [Re: off-roader] #1059705 05/18/13 10:35 PM
Already in mechanics hands! 23 bucks for that lil bugger. Guess Ill have to go talk to him bout heater hoses, wanted to order them from NAPA and pick them up after my shift. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: what should I replace after top end off***names of all heater hoses? [Re: cjsmontero] #1059706 05/19/13 01:28 AM
OE heater hose swap out is a good idea, yes.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6323 MB (Peak: 0.7408 MB) Data Comp: Off Server Time: 2026-06-07 08:33:59 UTC
