Wiring in an additional reverse light
#1059866
05/20/13 05:25 AM
Harbor Freight has these lights on sale. http://www.harborfreight.com/12-volt-halogen-vehicle-work-light-93904.html I have used them for lights on the front, doing the normal relay/switch/idiot light wiring. We have a night ride coming up, and the stock reverse lights leave a little bit to be desired. Anyone had experience with wiring a light like this into the standard reverse light wire and not thru a switched relay. Bumping up the fuse is mandatory, and I'm thinking it may not be as bright as when I wire them up on the work trucks, or tractors, but it has to be an improvement over stock
Re: Wiring in an additional reverse light
[Re: Mudraider]
#1059867
05/20/13 11:36 AM
I was able to replace my stock reverse bulbs for halogens, helps a little.
Direct wire would depend on amperage. On my pickup I installed the relay for add-on reverse lights behind the rear light lens for signal wire, then direct wired it to battery for power.
[Re: pcc]
#1059868
05/20/13 01:09 PM
I would recommend to use a fuse not directly to battery  But I have considered doing the same thing stock backup lights are not so great. for $7 thoes look pretty cool!
89 Monturbo (RIP now but the heart is in the 90!) 90 Montero with 2.6 turbo swap! (close to finished) 88 Starion MPI T3/T4 Magna M8 head..... 96 Volvo 850
[Re: Lizzord30]
#1059869
05/20/13 02:44 PM
I would recommend to use a fuse not directly to battery  But I have considered doing the same thing stock backup lights are not so great. for $7 thoes look pretty cool! Yes, $7 is a great price. And they work great. They aren't silly bright like the Rigid's or all their knock-offs, but I'm not trying to blind ants on the ground either.
[Re: Mudraider]
#1059870
05/20/13 02:53 PM
You could either run it directly in parallel off of the stock lights, or run it's own power source to it with a relay and run the relay power from the stock lights.
1992 VR4 12.5 @ 110 - SOLD 1993 Stealth RT/TT 11.4 @ 129 - SOLD 1991 VR4 9.2 @ 159 - Old Shop Car 1992 Stealth Twin Turbo ATX - SOLD 1990 Montero LS LWB - RIP 1995 Montero LS - RIP 1998 Montero 1992 Galant VR4 474/1000 2007 Prius
[Re: Mudraider]
#1059871
05/21/13 02:20 PM
Harbor Freight has these lights on sale. http://www.harborfreight.com/12-volt-halogen-vehicle-work-light-93904.html I have used them for lights on the front, doing the normal relay/switch/idiot light wiring. We have a night ride coming up, and the stock reverse lights leave a little bit to be desired. Anyone had experience with wiring a light like this into the standard reverse light wire and not thru a switched relay. Bumping up the fuse is mandatory, and I'm thinking it may not be as bright as when I wire them up on the work trucks, or tractors, but it has to be an improvement over stock So when where are you "night riding"?
[Re: sasnydley]
#1059872
05/21/13 02:55 PM
Hardrock MX and 4x4 Park in Ocala. Look at the events page. Look me up on FB. Frank Eck
[Re: Mudraider]
#1059873
05/22/13 11:00 PM
I will. We need need some place relatively close to go play. <img src="/forums/images/graemlins/kewl.gif" alt="" />Since I am back on 12 hr shifts and my nephew who is a medic and is also on shifts (he has 89 2dr V-6) <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: sasnydley]
#1059874
05/23/13 02:56 AM
I will. We need need some place relatively close to go play. <img src="/forums/images/graemlins/kewl.gif" alt="" />Since I am back on 12 hr shifts and my nephew who is a medic and is also on shifts (he has 89 2dr V-6) <img src="/forums/images/graemlins/patriot.gif" alt="" /> Hardrock in Ocala is only a couple hours away. Nowhere else in Florida are you gonna 200 yard hills on a 60? slope. June 8th, plenty of timeto get a schedule changed.
[Re: Mudraider]
#1059875
05/24/13 08:28 PM
Going to look into it. Thanks!
