Little G54B MPI project pics added #1059952 05/23/13 05:51 AM
boostin Offline OP
hey guys let me know what u thinks so far, and and constructive critisim is appreciated
https://picasaweb.google.com/104468856857940425738/G54BMPI?authkey=Gv1sRgCLreicmc6OWH-wE
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD!
1989 Mighty Max 2WD 2.6 5 speed slammed
1993 Eagle Talon TSI
Re: Little G54B MPI project [Re: boostin] #1059953 05/23/13 06:35 AM
geocrasher Offline
Shiny! What's your plan of action?
http://tidbitsfortechs.com/
Re: Little G54B MPI project [Re: geocrasher] #1059954 05/23/13 04:21 PM
Lizzord30 Offline
Looks good! You going turbo, or Just NA? What is your Length of the runners and what is your ideal Plentum size?
Keep it up!
89 Monturbo (RIP now but the heart is in the 90!)
90 Montero with 2.6 turbo swap! (close to finished)
88 Starion MPI T3/T4 Magna M8 head.....
96 Volvo 850
Re: Little G54B MPI project [Re: Lizzord30] #1059955 05/23/13 06:49 PM
boostin Offline OP
Runners will be about 16 long with velocity stacks inside the plenum...
Plenum is going to be approx 4x4 x 12
Going to be na for a while but maybe turbo if this does not add the power I am looking for
Re: Little G54B MPI project [Re: boostin] #1059956 05/23/13 08:06 PM
I like it. The Aussies got aabout 135hp out of the Magna with mpi, but that was with a different head with bigger valves. I think you will want a turbo...
I like the flange work. Flame or water cut? How will you plumb the two water outlets? I'd weld a bung on the slot and use a brass nipple for the hot water outlet to the bypass and heater. There is some good plenum sizing info on sdsefi.com in the tech articles. You could weld a hose nipple on the tstat outlet and use a remote bmw tstat housing.
Re: Little G54B MPI project [Re: fasteddy] #1059957 05/24/13 01:15 AM
boostin Offline OP
the flange was water cut, did a awesome job!!
I actually have the water flanges on there in some of the pictures, rear one is just a hose barb as suggested and the front one i got creative, used a 4g63 thermostat housing so i have a kazillion water outlets for sensors and water lines and what ever crazy i get up to
Re: Little G54B MPI project [Re: boostin] #1059958 05/24/13 05:23 AM
boostin Offline OP
added some pictures of the plenum i started to work on, its a 3x4 square tubing thats 12 long. little smaller then planed but still much larger then my magna.
also u can see how i did the thermostat housing.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6200 MB (Peak: 0.6947 MB) Data Comp: Off Server Time: 2026-05-29 22:32:54 UTC
