Rear Door Hing help........ #1060076 05/27/13 03:36 AM
TainterRacing Offline OP
I am wondering what others have done My upper one needs to be fixed or replaced. I tried a bit to get the pin out to try and fix it that way but did not get it out. Can I just buy a new one I am willing to do that, but looks like its about 120+ for that.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Rear Door Hing help........ [Re: TainterRacing] #1060077 05/27/13 04:22 AM
Czd3my Offline
Mine had a worn out pin and drug on the bumper when opened. I had to drill mine out. Then I increased the hole diameter to 11/16" and bought a grade 8 bolt long enough to be able to cut off the head and the threaded part. Bought needle bearings that were sealed on one side. I drilled a hole and threaded it for a set screw in the lower portion of the hinge to hold the bolt "pin" in place. I also used bronze washers between the door side and body side. Make sense?
In short my pin would not come out even using a 20T press! I had to find a way to fix it and thought I should make it stronger and last longer! Maybe it will work!
1998 Montero (CW Pack)
1979 Chevy LUV 4x4
2000 GMC 2500 4X4
Re: Rear Door Hing help........ [Re: TainterRacing] #1060078 05/29/13 01:30 AM
I got a pair from the JY when our 98 lost a pin. Had to paint them though.
My 95 Gen II had holes in the pin housing that I could spray into. Never had a problem. The 98 (and my 00 now) does have the hole. The 00 is now binding pretty bad and I fear for its future.
Re: Rear Door Hing help........ [Re: TainterRacing] #1060079 05/30/13 08:17 PM
kpytoi9 Offline
You can buy a new one...its a really simple install if you have 2 people since one will have to hold the door while you take the hinge off. You need to take both of the hinges off to replace one.
Re: Rear Door Hing help........ [Re: kpytoi9] #1060080 05/31/13 02:20 AM
Yes, but like he said, ~$120 each. I got the JY pair for ~$40. Hard pard is finding them as they are usually still on the doors. Need to find a rig with the door wrecked.
Re: Rear Door Hing help........ [Re: MontyMcV] #1060081 06/24/13 03:15 AM
I removed it drilled it out used 1/4in then up to a 3/8in and then after I got all the OEM stuff out I over bored it with a 1/2in and put a long 1/2 bolt in there. I removed the threads so its just a pin. Works great.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6104 MB (Peak: 0.6803 MB) Data Comp: Off Server Time: 2026-06-09 21:57:47 UTC
