Gen III Transfer Case Removal - Help Wanted #1060123 05/28/13 08:48 PM
Sabre Offline OP
I've pulled the orange blinky-light error code for the transfer case ECU on my '01 Montero Limited, and learned that the switch(es) are faulty (error code 33). I've ordered a set of five new ones.
I'm pretty handy, but have never pulled a transfer case before. Any guidance would be very much appreciated!
I could tell you more, but suddenly I am run over by a truck.
-Michael O'Donoghue, "How to Write Good"
Be kind whenever possible. It is always possible.
-the Dalai Lama
Re: Gen III Transfer Case Removal - Help Wanted [Re: Sabre] #1060124 05/28/13 09:26 PM
It honesty might be easier to just temporarily lift up the body enough that you can access the switches on top. In mine I have a 2" BL and I can access the switches to change them out. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gen III Transfer Case Removal - Help Wanted [Re: off-roader] #1060125 05/28/13 09:31 PM
Sabre Offline OP
No joy on a body lift on the Gen III models!
-the Dalai Lama
Re: Gen III Transfer Case Removal - Help Wanted [Re: Sabre] #1060126 05/28/13 09:45 PM
geocrasher Offline
I'd see if you can get the clearance you need by just unbolting the crossmember and let it all hang down a bit, maybe even give it a tug or two to push it down. Removal might be what the book says, but real world might be another story ;-) <img src="/forums/images/graemlins/zombie.gif" alt="" />
http://tidbitsfortechs.com/
Re: Gen III Transfer Case Removal - Help Wanted [Re: geocrasher] #1060127 05/29/13 05:12 AM
Ian Sharpe Offline
not sure on Gen 3 but on my Gen2 , if you take out the console & transfer lever then you have access to the switches.
As I say not sure on the gen 3 , but if it were me I would be cutting myself an access hole in the floor pan before I removed the transfer case, they are H U G E & weigh heaps, a real bugger of a job.
BTW I had the same code on my Gen3 & it went on for weeks (flashing CD light) but then it just fixed itself!! believe it or not, my next step was replacing the switches.
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6061 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-10-22 02:20:32 UTC
