Re: Gen 1 Tailgate/Rear Door Stay
[Re: rxinhed]
#1060271
06/05/13 11:34 PM
Will be visiting Flagstaff. I didnt think there were that many flat states in the west...
[Re: fasteddy]
#1060272
06/05/13 11:36 PM
you never know when some of your best work will come!
Thanks for the suggestion. Sort of what I was thinking if I couldnt get this Gen 2 stay to work! I am determined to get something working! Might have to take a trip to a wrecker/dismantler/recycler for ideas.
Andrew
[Re: awbeattie381]
#1060273
06/05/13 11:45 PM
IIRC, the gen2 works by having the stay pulled against spring pressure engaging a notch on the stay. That's why I used the idea I posted. I bet you could modify the gen1 stay to work approximately the same way.
[Re: fasteddy]
#1060274
06/07/13 02:39 PM
I use a window wedge. Its made of plastic and used to pry the tops of door jams to stick a jimmy in for unlocking. They come in several different sized and the plastic is really easy on the paint. I drilled a hole in it for a rope and slide it in the space between the door and the qtr pan. The rope is so I can reach and yank it out without getting my have in there. Seattle has some hills too. Cheers.
Seattle WA... (Everett) 1990 Montero LS OME complete, 2"BL,spray-paint. 1990 Montero LS in the 1st stage of rebuild. 2009 Pilot, Bone stock. "Let me put on my slightly larger glasses".
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6078 MB (Peak: 0.6796 MB) Data Comp: Off Server Time: 2026-06-22 06:12:20 UTCValid HTML 5 and Valid CSS
