Re: Gen 1 Tailgate/Rear Door Stay [Re: rxinhed] #1060271 06/05/13 11:34 PM
awbeattie381 Offline OP
Will be visiting Flagstaff. I didnt think there were that many flat states in the west...
Re: Gen 1 Tailgate/Rear Door Stay [Re: fasteddy] #1060272 06/05/13 11:36 PM
you never know when some of your best work will come!
Thanks for the suggestion. Sort of what I was thinking if I couldnt get this Gen 2 stay to work! I am determined to get something working! Might have to take a trip to a wrecker/dismantler/recycler for ideas.
Andrew
Re: Gen 1 Tailgate/Rear Door Stay [Re: awbeattie381] #1060273 06/05/13 11:45 PM
IIRC, the gen2 works by having the stay pulled against spring pressure engaging a notch on the stay. That's why I used the idea I posted. I bet you could modify the gen1 stay to work approximately the same way.
Re: Gen 1 Tailgate/Rear Door Stay [Re: fasteddy] #1060274 06/07/13 02:39 PM
DuCal Offline
I use a window wedge. Its made of plastic and used to pry the tops of door jams to stick a jimmy in for unlocking. They come in several different sized and the plastic is really easy on the paint. I drilled a hole in it for a rope and slide it in the space between the door and the qtr pan. The rope is so I can reach and yank it out without getting my have in there. Seattle has some hills too.
Cheers.
Seattle WA... (Everett)
1990 Montero LS OME complete, 2"BL,spray-paint.
1990 Montero LS in the 1st stage of rebuild.
2009 Pilot, Bone stock.
"Let me put on my slightly larger glasses".
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6075 MB (Peak: 0.6793 MB) Data Comp: Off Server Time: 2026-06-07 07:27:16 UTC
