Need a better brake booster #1060571 06/13/13 02:02 AM
jwthemechanic Offline OP
Well I finally got a starion engine in the montero but when I built it I used the cam that came with the engine. It is a little hotter that stock and I am only drawing about 17 in of vacuum, that doesn't assist enough. What are my options? Just put on gen2 calipers and disks, Swap cams, or maybe some sort of vacuum pump or bigger booster?
"Turbobitchero" (named by jealous wife) 87 swb base, 89 starion intercooled turbo engine, Bouncy seat, posi in rear, "miller locked" in the front with manual hubs, 3" BL, 305/70/16 bfg's. Sponsored by IAWDLR Racing
Re: Need a better brake booster [Re: jwthemechanic] #1060572 06/13/13 02:12 AM
How about one of those vacuum balls from an S-10 or Chevy to have a larger supply to work with? So you'll be ready to get to Hardrock in the next couple months?
Re: Need a better brake booster [Re: Mudraider] #1060573 06/13/13 02:49 AM
Vanco hydraulic assist? Electric-over-vaccum pump?
Parachute? <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Need a better brake booster [Re: Mudraider] #1060574 06/13/13 02:55 AM
DRX350 Offline
Fords have a (small) coffee can sized one on the late 70's trucks. They work great, I ran one on a mustang with a big cam.
"Does this part need to be in there?"
1996 Dodge 1500 single cab / short bed, 5.9 4x4; 2" lift (springs not blocks), C.A.I and more mods to come.
Re: Need a better brake booster [Re: DRX350] #1060575 06/13/13 05:18 AM
Starions had a vac pump and canister, too. To run the cruise, I guess....
Re: Need a better brake booster [Re: jwthemechanic] #1060576 06/13/13 02:56 PM
A
age67 Offline
Could use a vacuum resovoir as the old vehicles used to, in the '50's and '60's. looke like an orange juice can with two fittings soldered on, factory equipment, so it worked.
Eddie <img src="/forums/images/graemlins/cheers.gif" alt="" />
'88 Dodge Raider 2.6L, 5 spd.
Re: Need a better brake booster [Re: Mudraider] #1060577 06/13/13 04:16 PM
I will be up in D.C. around that time. However, if I can get the exhaust fabbed and everything dialed in I will be in your neighborhood in a week or two.
Re: Need a better brake booster [Re: jwthemechanic] #1060578 06/13/13 07:14 PM
Check the function of the inline check valve in the booster vac line. You should see much higher than 17" on decel if you are still in gear, and that vac should remain in the booster to be available on braking. Is the booster sound?
Re: Need a better brake booster [Re: fasteddy] #1060579 06/13/13 11:42 PM
DRX350 Offline
the check valves are a good place to start.
other wise this will work
Re: Need a better brake booster [Re: DRX350] #1060580 06/14/13 02:06 AM
Check valve (off a starion) is good and I haven't driven except around the block, but still should have had enough vac to help it stop. The booster was fine before the swap but with anything this old it could be. One problem after another, but is turning out nice. Just while trying to get it running and boosting I found a bad wire in the harness for the maf and at the same time had a coil that bench tested fine but was not(imagine that).
Eddie, What is that off of? I might have just enough room for something like that
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6373 MB (Peak: 0.7609 MB) Data Comp: Off Server Time: 2026-06-20 18:17:48 UTC
