Question for Addco swaybar veterans. #99981 11/07/02 10:00 PM
Rob_dup3 Offline OP
Last month I installed my front Addco sway bar and I've noticed over time that the bar shifts from side to side within the mounting brackets slightly. No more than 1/8 of an inch to either side. I noticed this because the grease near the mounting brackets is "pushed" away from the edges of the bushings.
Is this normal or OK? When I removed my stock front bar I didn't notice any evidence of shifting like this. That's why I'm wondering.
Should I tighten the bolts any more? Thanks.
http://community.webshots.com/user/medmaker100
Wheelwell lights, PIAA 959's under valance, Grant Burlwood steering wheel, Bilsteins X 4, Michelin Cross Terrain SUV's, Clear Bumpers, Deckplate, Front/Rear Addco bars, 1.5 Lift on a 4X2
Re: Question for Addco swaybar veterans. #99982 11/07/02 10:06 PM
mosk Offline
This isn't an answer but a followup question: what sort of grease did you use to grease your sway bar bushings?
Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: Question for Addco swaybar veterans. #99983 11/07/02 10:12 PM
Rob_dup3 Offline OP
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by mosk:
<strong>This isn't an answer but a followup question: what sort of grease did you use to grease your sway bar bushings?
Jeff</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I used Marine grease bought from AutoZone. Jalaber recommended it as the best to use.
Re: Question for Addco swaybar veterans. #99984 11/07/02 10:20 PM
Bratik Offline
I think it's normal, mine does it all the time and i've been using it for 2 years. I hope this helps.
Re: Question for Addco swaybar veterans. #99985 11/07/02 11:22 PM
Yes the shifting is normal, I've noticed the same thing. The anti-sway bar is designed to move a little, your 1/8" is good.
I'm always sure to check my mounting brackets and end links with every oil change.
As far as the grease, I also use the marine grade black grease.
BTW, I've had my Addcos for over 2 years now.
<small>[ November 07, 2002, 05:23 PM: Message edited by: Lifer ]</small>
Re: Question for Addco swaybar veterans. #99986 11/07/02 11:47 PM
Rob_dup3 Offline OP
Thanks all, just making sure nothing was wrong. That Addco bar definatelly makes handling so much sweeter.
R.
Re: Question for Addco swaybar veterans. #99987 11/08/02 02:43 AM
I got the rear Energy sway bar bushing and end link busing for stock bar, I feel little stiffer. Any body in here using any kind of better sway bar bushing for front stock bar.
where can I buy those bushings, and any one know
who sells Addco sway bar less money? I think I'll put Bilstein Shock and coil springs for my 3rd Gen 4Runner also. I need to shop around for that handling mods. Any one has tip to install addco sway bars?
Thanks first!
Re: Question for Addco swaybar veterans. #99988 11/08/02 04:40 AM
The shifting seems normal to me as well. I also notice it by the grease marks left. I use waterproof green marine grade grease. I just greased the ES bushing up this weekend, sure is simple with the zerk fitted brackets <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
Re: Question for Addco swaybar veterans. #99989 11/08/02 05:37 AM
Rob_dup3 Offline OP
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by 204runner:
<strong>I got the rear Energy sway bar bushing and end link busing for stock bar, I feel little stiffer. Any body in here using any kind of better sway bar bushing for front stock bar.
Thanks first!</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">The Energy Suspension swaybar brackets would be the best thing to use vs. the supplied bracket by Addco. Get the ones with the zerk fittings so you can re-grease them without taking them off. You'll find these at www.summitracing.com
As far as best prices for Addco swaybars, the 2 places that come to mind are www.shox.com and Performance Products. I got mine from PP but check Shox for their price. When PP had their 15% off sale the prices were good. Hope this helps.
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.6219 MB (Peak: 0.7226 MB) Data Comp: Off Server Time: 2026-06-07 06:07:59 UTC
