Dialing in and aligning ignition dizzy? #1060892 06/22/13 05:58 AM
RockU Offline OP
Anybody have a picture or diagram that shows how to dial in or align the ignition dizzy for a 2.6?
I installed a new distributor, set the timing, but after reading posts about dizzy alignment, didn't touch it..
Thanks..
RockU - Federal Way, WA - 1989 Montero, New-2.6L, New-5spd, New Clutch, header, 10x15 wheels, 32x11.5x15 Mud Claw (Cardovan), 4" lift, Superwinch Hubs, Front LSD, Synch 38/38 Weber Carb, K&N filter, (Let's hit the trail!) Home Email: jondanderson2002@yahoo.com
Re: Dialing in and aligning ignition dizzy? [Re: RockU] #1060893 06/22/13 08:50 AM
Set the crank on tdc for #1 cylinder. To be sure you are on #1, remove the spark plug and hold your finger over the hole and turn the crank to the tdc mark. As you do, your will feel hard pressure on the plug, indicating that #1 is on the compression stroke. Remove the dizzy. Rotate the shagt until the drilled mark on the shaft alighs with the cast mark on the housing. Slide the dizzy into the nole while you hold the marks in alignment, centering the adjustment slot on the stud. Let the shaft turn only when the gears start to engage. The rotor will align to about 9 oclock. this will set gross timing. Fine setting is done with a timing light, vac line to dizzy removed and pluged at 750rpm idle, 7-10*btdc, i.e, left of the zero mark.
Re: Dialing in and aligning ignition dizzy? [Re: fasteddy] #1060894 06/22/13 06:25 PM
RockU Offline OP
Thank you Fasteddy....
Re: Dialing in and aligning ignition dizzy? [Re: RockU] #1060895 06/22/13 06:56 PM
You are welcome. Installing a dizzy was on of the scary jobs back when I was a rookie shade tree wrench - so many ways to get it wrong, only one to get it right...
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6049 MB (Peak: 0.6608 MB) Data Comp: Off Server Time: 2026-11-02 12:30:47 UTC
