Not Charging on 1989 Raider 2.6
#1061350
06/28/13 08:19 PM
Just finished an engine swap on my old carbed 2.6 Raider up to a fuel injected turbo 2.6 running my Megasquirt system. Fired up like I never had the engine out but noticed I was not charging (same alternator I was running that was great). Swapped out to another spare I had, still no charge. I've traced all wires from the alternator post to the battery terminal including the fusible link and that side is all good. Trying to figure out how to check the wires from the alternator plug (although I guess one is tied to the idiot light in the cluster which is staying on of course). While there is always a chance I have 2 bad alternators (given both worked fine when removed) I want to confirm everything else before pulling another alternator.
Any ideas or advice?
1989 Nevada Sand Raider 2.6 5-speed Turbo FI with Megasquirt
Re: Not Charging on 1989 Raider 2.6
[Re: jonboyb]
#1061351
07/01/13 02:14 PM
Now I'm really stumped......both alternators tested fine. Battery tested fine. Wiring from alternator "B" post through 100A and 40A fusible links to battery....perfect. Large wire to alternator plug (source volatage wire from battery).....perfect. Small wire to alternator plug (for gauges)...perfect. There's no reason I can find for no charge....anyone have an idea?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5878 MB (Peak: 0.6366 MB) Data Comp: Off Server Time: 2026-06-10 07:26:19 UTCValid HTML 5 and Valid CSS
