OK - I replaced the Master and Slave cylinders.
Anybody got a concise cheat sheet on bleeding the system?
Try this ...
On brake calipers the bleeder is on 'top' ..Right ...?
Air bubbles go up as in your beer ..
Well now look at the clutch slave ...The bleeder is on one end and the air is on the other ..Its not up hill ...So how does one get the air to get to the bleeder ?...Try this ..
GET TWO PEOPLE ...!!!!!!
Unbolt the slave let it hang ..Now the bleeder is 'up hill' ..One person under the truck.. Crack the bleeder ...The other person "just tap' the clutch pedal a few times until the fluid starts pissing out the bleeder at the slave ...Person up top most have the brake fluid bottle open and ready or gravity will take over and emty the master faster then you think.. BEWARE once the fluid starts to flow ...You do not have time to get out from under the truck get the brake fluid and get it pored into the master...Thats why you need two people ..You can do it with one but have it all ready ... DO NOT push the pedal to the floor and leave the master cap off ...Bleeding a clutch like brakes is a pissing contest ...When you bleed brakes the brake pads/shoes bottoms out.. Then the fluid has to go somewhere so out the bleeder thats 'up hill' it goes ... Clutch system 'never' bottoms out and the bleeder is 'not up hill ...Try that ..
PS brake fluid take off paint becareful...!!
Have a good day
Captain Gear Box
Hazardous Toys inc..
(The powers to be around here should clean up my spelling put this info some where safe it is the easyest way to bleed a slave ...I've brang this up a few times but the info does not seem to sink in...)
