Cleaning deck / Flushing Coolant Passages - G54B Block
#1061379
06/29/13 07:10 PM
I'm about to install the a new head onto my block. G54B / 2.6L. The block has been head-less for a couple months with the Montero outside so I want to thoroughly clean the deck and combustion chambers.
I'm using a rag and a little WD40, following up with a wipe down with some motor-oil on a rag for the cleaning.
Should I be worried about any possible debris/particles that might have fallen into the coolant passages through the top of the block? If so, what is the best way to go about flushing?
I imagine the easiest way is to let the water pump do the work after the cooling system is back together, but would I be better off doing this earlier to prevent cycling any foreign matter through the cooling system?
Thanks all!
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5844 MB (Peak: 0.6247 MB) Data Comp: Off Server Time: 2026-06-07 04:38:58 UTCValid HTML 5 and Valid CSS
