Overdrive Relay V4AW3 - Solenoid Pack - Coolant Bottle #1061775 07/07/13 11:51 AM
Pete_D Offline OP
Anyone have the PN for these? OD is strong but only works 65-70% of the time with an 600/900RPM gain.... I have a buddy coming back here (Thailand) soon & can have him hand carry back if needed. Also need the stock coolant bottle & cap..... replacement here is about 1/2 sized and I'm not comfortable with it.....
Side note - KC 130 watt Daylighters are on the way for the ARB (clone/real?) front bumper.....Soon to come a stainless steel reproduction of the Trail Armour Rock Sliders which should be cheap here to duplicate.....need a good back up light alternative too
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: Overdrive Relay V4AW3 - Solenoid Pack - Coolant Bottle [Re: Pete_D] #1061776 07/07/13 05:54 PM
mxmikie Offline
on the OD kicking in and out better check the sending unit in the intake for that problem it is the problem 99% of the time
Re: Overdrive Relay V4AW3 - Solenoid Pack - Coolant Bottle [Re: Pete_D] #1061777 07/07/13 06:32 PM
I use these lights, which work fine as reverse lights, until you bash them on rocks. No biggie; they're cheap.
Lights
Re: Overdrive Relay V4AW3 - Solenoid Pack - Coolant Bottle [Re: mxmikie] #1061778 07/08/13 03:47 AM
Pete_D Offline OP
It's a 2.8 diesel - I do not see any sending units - I'll look somemore
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6025 MB (Peak: 0.6584 MB) Data Comp: Off Server Time: 2026-05-29 20:01:29 UTC
