Where to buy a output shaft seal and auto trans mount #1062419 07/27/13 11:54 PM
jwthemechanic Offline OP
Need to find parts source for 87 swb 2.6 automatic montero.
I need to find a transfer case rear output shaft seal. The auto parts store gave me Timken 224052 but I.D. is too large. The parts catalog calls for MD731708 and from what I gather it has the same ID as the 224052. Maybe the one listed for the front will work as it has a smaller ID and the same O.D.
I also need to find an auto trans mount. I have ordered from advance disappointment auto and Rockauto and got the wrong one both times. They keep sending one for a manual trans. Is the stealer my only option?
"Turbobitchero" (named by jealous wife) 87 swb base, 89 starion intercooled turbo engine, Bouncy seat, posi in rear, "miller locked" in the front with manual hubs, 3" BL, 305/70/16 bfg's. Sponsored by IAWDLR Racing
Re: Where to buy a output shaft seal and auto trans mount [Re: jwthemechanic] #1062420 07/28/13 08:11 AM
Mitsubishi Parts dot Net
<a href="www.oemmitsubishiparts.com/" target="_blank">OEM Mitsubishi Parts</a>
Try these.
Re: Where to buy a output shaft seal and auto trans mount [Re: rxinhed] #1062421 07/28/13 04:15 PM
Thanks and I will most likely go this route for the mount.
The seal is what I am most concerned with because the one listed in the parts manual is not correct, at least mine is different. Has anyone replaced this seal and not had this problem?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5960 MB (Peak: 0.6497 MB) Data Comp: Off Server Time: 2026-06-07 07:26:23 UTC
