Aftermarket Oil Pressure Gauge for G54b #1062478 07/29/13 01:02 PM
jonboyb Offline OP
I would feel a whole lot better on my new turbo swap to have a real oil pressure gauge. However, the extra port on the oil filter housing (from Starion for cooler lines) where a Starion would have a gauge sender is totally blocked by the power steering pump. Then the gallery port has the factory Gen1 sending unit. Anyone mount an additional aftermarket unit?
Thought about having a block machined to accept 2 sending units (factory one with 1/8" BPT thread and aftermarket with 1/8" NPT) to screw into the factory port, but being BPT makes it a disaster trying to find a tap and die set.
1989 Nevada Sand Raider 2.6 5-speed
Turbo FI with Megasquirt
Re: Aftermarket Oil Pressure Gauge for G54b [Re: jonboyb] #1062479 07/29/13 01:54 PM
MainstreaM Offline
BPT is NPT just not tapped as deep. Take an NPT tap and run into it a little bit to enlarge the hole to NPT standards. This is in the SOS manuals somewhere. I've done it on 87 B71 car I used to have. You can then easily find a brass street tee like this.
Kane
Re: Aftermarket Oil Pressure Gauge for G54b [Re: MainstreaM] #1062480 07/29/13 03:07 PM
jonboyb Offline OP
I think there is also a minimal pitch difference to the threads too....like -27 vs. -28. It's not much and a brass fitting would likely distort enough that it wouldn't matter.
Re: Aftermarket Oil Pressure Gauge for G54b [Re: jonboyb] #1062481 07/30/13 12:31 AM
I used a 28-tpi fitting for a 27-tpi application once-upon-a-time (Chevy LUV) and did not have any issues until I crashed the truck.
Re: Aftermarket Oil Pressure Gauge for G54b [Re: rxinhed] #1062482 07/30/13 02:01 AM
BPT is a straight thread, NPT is tapered, and while it can be done, it's very hard to start and NPT male into a BPT female. Lightly tap it with an NPT tap, testing until you get a good start on the HPT fitting, and even after tapping, you can still use a BPT in the same hole with some teflon tape.
If you buy a half inch longer PS belt, you can use a street ell (m x f threads) in the location just behind the timing belt.
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6077 MB (Peak: 0.6730 MB) Data Comp: Off Server Time: 2026-11-20 00:16:04 UTC
