Sportage headlight upgrade #1062553 08/01/13 12:48 AM
cooking5 Offline OP
Trying to upgrade bulbs in dim headlights (2002) after cleaning the front lens. Stuck getting the plug off the back of the bulb. Manual says pull it off but is there a clip- its not moving? I can tell I'm pulling against the retaining spring wire (the next step inside the rubber boot)
Budget Backblocks exploring
Re: Sportage headlight upgrade [Re: cooking5] #1062554 08/02/13 01:47 PM
Everet Offline
You need to unhook the spring wire and it will rotate it out of the way.
A simple upgrade is to go with 50W HID Bi-Xenon HID lights. Good ones will cost around $120 for a complete kit. I have had good luck with Xentec brand.
I also like the 4300k color. Not the real blue ones.
Good Luck
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Sportage headlight upgrade [Re: Everet] #1062555 08/16/13 09:26 AM
cooking5 Offline OP
Thanks for the suggestion Everet. I already had the bulbs and they are much improved. Finally got into the wild last weekend and was very happy with the ride and grip of the kia.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.5927 MB (Peak: 0.6460 MB) Data Comp: Off Server Time: 2026-07-17 02:19:08 UTC
