How Does This Come Off? #1062676 08/05/13 02:41 AM
dannytuned Offline OP
The arm on the torsion bar, that is. The other end slid right off the splines. I have a feeling it is pressed on, but wanted to make sure before i try any harder to get it off.
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
Re: How Does This Come Off? [Re: dannytuned] #1062677 08/05/13 04:09 AM
I held the bar and used a 2-pound something rubber mallet to persuade the end off.
Re: How Does This Come Off? [Re: dannytuned] #1062678 08/05/13 04:59 AM
jdavis Offline
Mine slide off fairly easily when I reindexed them.
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: How Does This Come Off? [Re: dannytuned] #1062679 08/05/13 05:22 AM
geocrasher Offline
Reminds me of the way to separate a birfield from the inner axle on a Toyota. Get a metal tube/pole long enough and bigger than the torsion bar but not bigger than the bracket you're trying to remove. Just drop it in there from a height. Inertia should separate the two ;-)
http://tidbitsfortechs.com/
Re: How Does This Come Off? [Re: geocrasher] #1062680 08/05/13 06:13 PM
Thanks guys, I like that pipe idea!
Re: How Does This Come Off? [Re: dannytuned] #1062681 08/08/13 12:57 AM
It took some effort but it came off. I used Geo's idea and slid some nice heavy .250 DOM over the bar and used it as a slide hammer.
Then a little trimming for it's new application. <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks again.
Re: How Does This Come Off? [Re: dannytuned] #1062682 08/08/13 03:53 AM
geocrasher Offline
Awesome! Glad that worked out for you. On the Toyota's we'd drop the inner axle into the tube and the birfield would hit really hard, and inertia would break the clip inside the birfield and the inner axle would fall right out. Then you'd tack weld then grind down a spot on the splines to keep it from going too far into the birfield... neat hack on those. Did a disk brake conversion on a FJ55 that way. But that's for another forum.
So, what are you going to use that for?
Re: How Does This Come Off? [Re: geocrasher] #1062683 08/08/13 01:29 PM
Rear swaybar.
Re: How Does This Come Off? [Re: dannytuned] #1062684 08/08/13 06:11 PM
jdavis Offline
Rear swaybar.
Umm, rear swaybar???? More details please <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
Re: How Does This Come Off? [Re: jdavis] #1062685 08/09/13 01:23 AM
Got the idea here. I currently run no swaybars and my rear axle is articulating more than the front. A swaybar will stiffen the rear and make the front flex more, and improve road manners at the same time.
Got started on one of the arms today. This one will bolt to the control arm end.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6336 MB (Peak: 0.7422 MB) Data Comp: Off Server Time: 2026-06-07 04:46:13 UTC
