Help Please...Another Gen1 Front Hub Question - Axle Clip
#1062788
08/06/13 12:45 AM
Went to change my front rotors and pads tonight, and on the passengers side hub the axle lock clip behind the front beauty plate was laying loose in there. It snaps on the axle tip tight but it wasn't even on there. Shim looks intact and was still around the axle. Clip doesn't quite look like I expected either, I guess I expected to see eyelets on the ends...not blunt ends. Anything to worry about? Everything else looks great (other than separating the hub and rotor was an exercise in hammer swinging ). <img src="/forums/images/graemlins/lol.gif" alt="" />
1989 Nevada Sand Raider 2.6 5-speed Turbo FI with Megasquirt
Re: Help Please...Another Gen1 Front Hub Question - Axle Clip
[Re: jonboyb]
#1062789
08/06/13 01:35 AM
Sounds like some new clips are in order. They shouldn't be too loose, certainly not able to fall off on their own.
[Re: rxinhed]
#1062790
08/06/13 01:48 AM
It clips back on very tight....I wonder if it just wasn't installed right. Looked everywhere and can't find a part number or vendor.
[Re: jonboyb]
#1062791
08/06/13 01:58 AM
[Re: rxinhed]
#1062792
08/06/13 02:32 AM
Yep, and Rockauto, etc too....all my normal Starion parts stomping grounds. Good friend is the parts manager for a local Mitsu dealership so I guess I'll get him to drag out the microfiche tomorrow...LOL.
[Re: jonboyb]
#1062793
08/06/13 03:26 AM
I think they pop off when the axle does a maximum drop and deos it hard. I've had them pop off, too. I just whammed it back on there.
[Re: fasteddy]
#1062794
08/06/13 12:05 PM
Dangit...you mean no more Bo and Luke moves???? I can't find anything wrong so unless I can get ahold of new clips quick and easy, back on it goes for me as well.
[Re: jonboyb]
#1062795
08/06/13 01:25 PM
Clips and shims still available through Mitsu per my buddy. Will post part numbers once they arrive.
[Re: jonboyb]
#1062796
08/07/13 02:26 AM
Nah, those little jumps are ok. It's the Smokey and the bandit jumps, like the one they did over the Black Warrior River on the old US78 bridge, that do the damage.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6262 MB (Peak: 0.7129 MB) Data Comp: Off Server Time: 2026-11-03 13:38:50 UTCValid HTML 5 and Valid CSS
