4dr fuel tank in 2dr ?
#1063194
08/23/13 03:00 AM
Tanks leaking at the seams in my 89 v6. I can find some 4dr tanks in yards, will they fit the 2dr? Thanks Mike
89 v6 Raider 5spd 89 v6 Montero auto 86 TD Trooper
Re: 4dr fuel tank in 2dr ?
[Re: mike71800b]
#1063195
08/23/13 03:32 AM
No, 4dr is too big. If its a leak at the seam, find a local rad shop that would leak test it and braze the leaks. I fixed motorcycle tanks by pressuring the tank (8psi) and when finding the pinhole, sand it down and apply a thin film of JB weld then sand it flat and paint over the repair. Hope that helps. I know my 2dr tank is leaking on the top where debris and road salts collect. Doubt that will be fun...
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: mike71800b]
#1063196
08/23/13 03:32 AM
No. Too big. The 4-door tank is 24-gallons, the 2-door is only 20-ish. Dimensions are much different.
[Re: mike71800b]
#1063197
08/23/13 03:37 AM
Thanks guys
[Re: mike71800b]
#1063198
08/23/13 03:58 AM
I should have asked, how about the 4cylinder 2dr tank?
[Re: mike71800b]
#1063199
08/23/13 04:06 AM
[Re: StockRaider]
#1063200
08/23/13 04:16 AM
Thanks for the info again!
[Re: mike71800b]
#1063201
08/23/13 04:18 AM
If you need a tank, try car-part.com and look for them in snow free and saltwater free areas. <img src="/forums/images/graemlins/kewl.gif" alt="" />
