Page 1 of 3 1 2 3
Gen1 Fuel Pickup Issue #1063326 08/27/13 10:44 PM
jonboyb Offline OP
2.6 Gen1 with Starion engine/turbo/TBI conversion and Megasquirt running 6AN fuel feed from Walbro 255lph pump. I've driven around 3000 miles now and it's been PERFECT other than a couple of occasions where I noticed it was studdering when the clutch was pushed in and braking. Took me a while to figure out the common denominator. It only happens 1/4 tank or less (still a good 3-4 gallons left based on fill-ups) and I brake hard when turning right. I'm actually around 1/8 right now and can make it do it consistently. But only braking aggressively while turning right (like into my driveway). Can actually hear the pump lose suction for a split second with the windows up/radio off/etc.
I can't tell squat from my manuals about how the pickup sits in there. Any recommendations or is the 255 pump and large fuel lines just pulling too much fuel for a tank/pickup designed for a little carb? Don't want to pull tank till I have a good plan. Any advice would be appreciated.
1989 Nevada Sand Raider 2.6 5-speed
Turbo FI with Megasquirt
Re: Gen1 Fuel Pickup Issue [Re: jonboyb] #1063327 08/27/13 11:31 PM
No need to pull it. There should be a gas pump access panel in the floor underneath your carpet. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gen1 Fuel Pickup Issue [Re: off-roader] #1063328 08/28/13 01:15 AM
jonboyb Offline OP
Any chance that was on the V6 Gen1's only??? My fuel pump was mechanical underhood.
Re: Gen1 Fuel Pickup Issue [Re: jonboyb] #1063329 08/28/13 01:30 AM
Lloyd Swartz Offline
Yes, on 4cyl it is on the engine. All others it is in the tank accessed via a hatch under the carpet. Why don't all cars have that <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Gen1 Fuel Pickup Issue [Re: Lloyd Swartz] #1063330 08/28/13 01:47 AM
jonboyb Offline OP
Sawzall is your friend <img src="/forums/images/graemlins/lol.gif" alt="" /> I've added a larger FP hatch to most of my Conquests and Starions over the years. Dropping tank for the yearly fuel pump change gets old....stupid ethanol.
Re: Gen1 Fuel Pickup Issue [Re: off-roader] #1063331 08/28/13 02:11 AM
Part of Ray's suggestion is true. The pickup is located on the front left side of the tank, mounted to the same plate as the fuel gauge float assembly. There are no access points from within the cab. You have access behind the rear axle, 5 or 6 Phillips screws to remove.
Pics:
Re: Gen1 Fuel Pickup Issue [Re: rxinhed] #1063332 08/28/13 02:51 AM
jonboyb Offline OP
My fuel pickup line is hooked to a barb sticking out the front side of the tank??? Not from the plate like that picture....it's literally formed in the front of the tank. Something goofy about my tank???
Edit: I'll dig through my photos or take a new one. Now I'm confused.
Re: Gen1 Fuel Pickup Issue [Re: jonboyb] #1063333 08/28/13 04:23 AM
My 87's tank is like in Russ's pics, fwiw...
Re: Gen1 Fuel Pickup Issue [Re: MontyMcV] #1063334 08/28/13 06:10 AM
My 87 was the same as shown, and I've seen an 89 4cyl and it was the same as well.
My astrovan had the same problem, except at any fuel level below 1/4 tank and any state of acceleration.
The only fix I can see is a fuel dam around the pickup with doors that only swing in. I think the FI tanks have one built in, or so I remember from having my tank out and having it tanked to get the old fuel and rust out.
Re: Gen1 Fuel Pickup Issue [Re: fasteddy] #1063335 08/28/13 06:54 AM
So only the v6's have the access port? That sucks if you need to access the top of the tank...
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6416 MB (Peak: 0.7672 MB) Data Comp: Off Server Time: 2026-06-07 11:35:55 UTC
