Page 2 of 3 1 2 3
Re: Gen1 Fuel Pickup Issue [Re: off-roader] #1063336 08/28/13 08:40 PM
LandRaider Offline
I'm pretty sure I pulled my gen1 4cyl fuel pickuptube assembly out of the front of the tank from underneath.
Re: Gen1 Fuel Pickup Issue [Re: LandRaider] #1063337 08/28/13 11:37 PM
Yes, pretty easy...
Re: Gen1 Fuel Pickup Issue [Re: fasteddy] #1063338 08/29/13 12:57 AM
jonboyb Offline OP
OK...now I understand after crawling under my Gen1....that is the WORST idea ever. I thought that plate was braized onto the front of the tank...didn't realize it was just screwed on. So you're relying on a rubber gasket when over 1/2 tank to prevent leakage.....I'm dang near afraid to take it loose!!!
Anyone have a picture with correct orientation in the event mine is wrong (or are the holes spaced to prevent mounting it wrong)? Just trying to figure out the fuel pickup loss with 3-4 gallons still in the tank. Thanks again guys!
1989 Nevada Sand Raider 2.6 5-speed
Turbo FI with Megasquirt
Re: Gen1 Fuel Pickup Issue [Re: jonboyb] #1063339 08/29/13 01:02 AM
Just install it so the pickup is as low as possible. Hard to get wrong...
Re: Gen1 Fuel Pickup Issue [Re: jonboyb] #1063340 08/29/13 01:04 AM
It's five screws, indexing is not a problem. Pickup tube points down.
Re: Gen1 Fuel Pickup Issue [Re: rxinhed] #1063341 08/29/13 01:09 AM
jonboyb Offline OP
I was just wanting to confirm I'm actually pulling from the pickup right now instead of the return line without pulling it <img src="/forums/images/graemlins/smile.gif" alt="" /> If my fuel pump is pulling off the return line....that answers my issue...LOL.
Actually....no need. Looking at those pictures the pickup is the larger diameter one. Headed outside to crawl under again!
Re: Gen1 Fuel Pickup Issue [Re: jonboyb] #1063342 08/29/13 01:54 AM
jonboyb Offline OP
Nope....I have it hooked up right <img src="/forums/images/graemlins/frown.gif" alt="" />
Just a thought, I'm running a 255 lph pump and that return exits right at the pickup.....think I may be frothing/aerating the fuel when levels get low since I'm returning a TON a fuel??? Then the pickup sucking bubbles???
Guess I have to pull it no matter what to check for pinholes in the pickup tube.
Re: Gen1 Fuel Pickup Issue [Re: jonboyb] #1063343 08/29/13 02:23 AM
Quit stalling and take it out.... <img src="/forums/images/graemlins/lol.gif" alt="" />
The pickup sock will block the bubbles with it's mesh. IIRC, there's a rubber hose piece in there, too.
Re: Gen1 Fuel Pickup Issue [Re: fasteddy] #1063344 08/29/13 02:32 AM
jonboyb Offline OP
Nothing better than going to bed smelling of gasoline....that should turn the Mrs. on <img src="/forums/images/graemlins/lol.gif" alt="" />
You mean like a rubber hose inside the sock?
Re: Gen1 Fuel Pickup Issue [Re: jonboyb] #1063345 08/29/13 02:58 AM
No, I take it back, since there's no fuel pump in the tank like a stock FI engine has. However, if the truck sat with bad fuel in it, you could have rust holes in the steel pickup tube...
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6401 MB (Peak: 0.7650 MB) Data Comp: Off Server Time: 2026-10-26 07:55:33 UTC
