Time for Valve Stem Seals #1063785 09/09/13 05:03 PM
A
azazel Offline OP
Well after fixing the broken butterfly valves and doing the timing belt/water pump the truck has started to smoke after idling. I expected this yet didn't have the time to wait for the remaining parts to do the valve stem seals. Thus, I will be going back in this weekend. I actually like that I have to go back into the motor so I can check my work :-) . Although, its a lot of extra work.
Anyway, these are the parts that I think I need. Can anyone confirm if I am missing anything. The valve spring tool I have access too should work (so says the buddy that owns the shop). Thus I think I only need the following:
Spark Plug Seals MD186787 6 3.88
Rocker Cover Gasket MD186786 2 20.18
exhaust seals MD307343 12 3.21
intake seals MD306079 12 3.17
This is for the 3.5 DOCH (95 SR). Should I be adding the CAM seals too since we are already in there?
1994+1995 Montero SR
2003 Montero Limited
1990 Mighty Max 6G72 4x4
2014 Outlander Sport (Wife)
1992 Galant VR4 (724)
2004 Mitsubishi Lancer Evo RS - (SOLD)
+ Other Non Mitsu's
Re: Time for Valve Stem Seals [Re: azazel] #1063786 09/09/13 06:11 PM
ryany Offline
Definitely do the cam seals while you're there, and replace the spark plugs if you haven't already.
The space available to fit a valve spring compressor around the valve springs is ridiculously tight on your engine, and 99% of the valve spring compressors just won't fit. Unless your buddy who owns the shop has used his spring compressor on this motor specifically, I'd lay money on it not being usable.
95 Montero SR
Re: Time for Valve Stem Seals [Re: ryany] #1063787 09/09/13 06:18 PM
87Montero Offline
Does the same apply for the SOHC 24v 3.5? You've got me a little worried now, I am due for the valve stem seal replacement too. I noticed this summer season that If I let my truck idle for more than 10 - 15 minutes I will get "that smell" when I rev it up after sitting.
"that smell" is only recognized from when I was behind Stockraider's rig at a stop light a few times a while back when his did it but alot worse. <img src="/forums/images/graemlins/smile.gif" alt="" />
Anyway, what spring compressor does fit?
Re: Time for Valve Stem Seals [Re: ryany] #1063788 09/09/13 06:25 PM
A
azazel Offline OP
I think he has this one: http://buy1.snapon.com/catalog/item.asp?...amp;dir=catalog
I was thinking of purchasing the correct tool and keeping it with me so when we get stuck because his won't fit I can pull the I told you so card....and then bust out the tool to finish the job. A little friendly banter.
+ Other Non Mitsu's
Re: Time for Valve Stem Seals [Re: azazel] #1063789 09/09/13 06:41 PM
Canyonero Offline
If you go the purchasing route, this is the correct tool, and I've used it on both the DOHC, and SOHC engines now with success. And much cheaper than the one you linked to.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Time for Valve Stem Seals [Re: Canyonero] #1063790 09/09/13 07:42 PM
mxmikie Offline
and if you do not want to buy the tool i have one i rent out tool i rent out
Re: Time for Valve Stem Seals [Re: Canyonero] #1063791 09/09/13 09:24 PM
A
azazel Offline OP
I did purchase the tool. It will come in handy when the sport needs the work done. If the Snap-on one ends up working I can always return it. Everything has been ordered so I will plan to get started on Friday evening.
Thanks!
+ Other Non Mitsu's
Re: Time for Valve Stem Seals [Re: 87Montero] #1063792 09/10/13 11:34 AM
P
pcc Offline
At least for the 12 valve this tool works
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6232 MB (Peak: 0.7233 MB) Data Comp: Off Server Time: 2026-05-29 22:22:19 UTC
