rusted out gas tank 2002 #1063805 09/09/13 07:50 PM
coup Offline OP
soldered one hole,then found 4 or so more,,figure time for a tank....called about a junked one....
if have to go new wondered how i was suppose to get old one(fuel pump) out of tank....i have the tank off.....not sure what the
type of screws is,,guess if went new i would have to take out the other two things in tank also....what holds the fuel pump and other things in and best way to get them out for reuse.??
Re: rusted out gas tank 2002 [Re: coup] #1063806 09/10/13 08:12 PM
coup Offline OP
has no one ever put in a new fuel pump or took one out...
Re: rusted out gas tank 2002 [Re: coup] #1063807 09/11/13 12:29 AM
coup Offline OP
bought a junk one,,,breathers are differant but will make work.
Re: rusted out gas tank 2002 [Re: coup] #1063808 09/12/13 01:26 AM
coup Offline OP
installed took for ever by myself.....only had about 3 gallon,,didn't start but will try again tomorrow after pouring in another 5 gallon...
Re: rusted out gas tank 2002 [Re: coup] #1063809 09/12/13 06:32 PM
Dryver Offline
Hadn't been on for several days and just saw your post. I had to replace my gas tank, but the screws securing the fuel pump were severely rusted. I just ground the heads off of them so that I could pull the fuel pump and used new screws to put it on the new tank.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD.
GONE, all I have left are a few spare parts and the wheels.
Re: rusted out gas tank 2002 [Re: Dryver] #1063810 09/12/13 09:20 PM
coup Offline OP
thanks,,,,i saw the screws on the newer tank,,,,,got sporty started but had a severe leak....has to be one of the lines or the breather's that i rigged....have to wait ,till i have someone else to start and shut er off,,to see which ones...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6069 MB (Peak: 0.6758 MB) Data Comp: Off Server Time: 2026-07-09 17:11:11 UTC
