Gen 2 AC Pulley Bearing #1063925 09/14/13 08:48 PM
L
Lesharoturbo Offline OP
For those who are interested, it is available via Bearings Direct.com
Part # 30BGS10DST2
94 LS 3.0
Re: Gen 2 AC Pulley Bearing [Re: Lesharoturbo] #1063926 09/27/13 01:54 AM
MrJeebs Offline
Part # 30BGS10DST2
Excellent! Thank you sir! I will be needing to do mine very soon...
May I ask, did you do the job yourself, or did you take it somewhere. If you did it yourself, would you mind sharing how it went for you?
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Gen 2 AC Pulley Bearing [Re: MrJeebs] #1063927 09/27/13 08:40 PM
P
pcc Offline
I can't speak for Lesharoturbo, but I disassembled and reassembled mine with new seals. It was not hard at all. Did not do the bearing as it was OK. The bearing may need to be pressed out/in?
Re: Gen 2 AC Pulley Bearing [Re: pcc] #1063928 09/28/13 06:16 PM
L
The pulley bearing is real easy to replace, about 10 minutes tops. The hard part is getting the AC clutch off with the fan installed. My pulley came off with a few taps of a rubber mallet. Press out the old and press in the new or bang it out and tap in the new one like I did. <img src="/forums/images/graemlins/lol.gif" alt="" />
94 LS 3.0
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.5994 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-07-17 02:20:09 UTC
