manual hub kicking in -out #1063962 09/16/13 12:57 AM
coup Offline OP
my sporty has been sitting alot this summer due to gas tank leak....fixed the tank and now drivers side manual hub sounded like was kicking in and out,,,,,i turned them out and noise quit.....would taking off and lubing help?//?
Re: manual hub kicking in -out [Re: coup] #1063963 09/16/13 06:10 AM
Peabody Offline
Yes, it sounds like it would be a good idea to pull the hub and check out the innards. Might just need a good clean and lube. The manual hubs are pretty simple and easy to work on. They're also quite bullet proof. So I'm betting they just need a good clean out and repack with fresh grease (do both, just for good measure).
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5860 MB (Peak: 0.6338 MB) Data Comp: Off Server Time: 2026-07-09 17:11:09 UTC
