New guy here with 1994 Montero SR #1063971 09/16/13 05:01 PM
MichaelV Offline OP
Hey everyone!
Just registered for the forum. I have a 1994 Montero SR that I just got back on the road after being non-op for 8 years(long story).
I'm a member of a couple of Mitsubishi forums but they seem to have just died as far as active helpful users. My SR has a few minor issues I need to resolve and I found a bunch of helpful info here to go through.
Thanks
'94 Montero SR
Re: New guy here with 1994 Montero SR [Re: MichaelV] #1063972 09/16/13 05:50 PM
Welcome to the Wire, Michael! Enjoy that truck and post up any questions you have; there's a bunch of helpful people on here and you'll get quick answers.
Re: New guy here with 1994 Montero SR [Re: MichaelV] #1063973 09/16/13 06:29 PM
Looking forward to getting a chance to help you with your questions...
Re: New guy here with 1994 Montero SR [Re: off-roader] #1063974 09/16/13 06:37 PM
tonygon Offline
Great to have you. Get those questions on here for good replies. Im in san diego also <img src="/forums/images/graemlins/kewl.gif" alt="" />
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
Re: New guy here with 1994 Montero SR [Re: tonygon] #1063975 09/17/13 03:26 PM
MichaelV Offline OP
Thanks for the welcome everyone! Here are the issues currently.
1) Speedometer/odometer isn't working. I noticed this morning they did work for about 2 minutes, then quit. Then worked again, then the needle jumped around some. I've done a visual inspection of the wire going to the speed sensor but haven't pulled it or the instrument panel yet. I found some info on this forum about the board on the back of the speedo burning some traces on a couple guys '94's so I guess I need to take a look at it.
2) Fuel gauge needle isn't working, but the low fuel light on the dash does work. I'm guessing I'll have to get to the tank and take a look, haven't found much info on this.
3) Locking front hub indicator lights flash randomly at times, without touching the lever. Not sure what is going on here, some kind of sensor malfuction? I have cycled the transfer case a number of times to no avail. Also, I can't remember what the normal status of the rear indicator lights should be in 2H. They are currently off. I found a couple of threads here about troubleshooting this so I'm going to read up on them.
Any help you guys could give would be great! So far this site has the most organized info on the Montero that I've found.
'94 Montero SR
Re: New guy here with 1994 Montero SR [Re: MichaelV] #1063976 09/17/13 03:58 PM
WigWiggy Offline
For #3, your rear wheel indicator light bulbs are probably just burnt out from being on constantly. They're just a silly gimmick. For the front blinking lights, read this. But also don't be surprised if the problem goes away after you drive for awhile and cycle the 4WD system regularly. The system gets grouchy from lack of use, but can often be cheered up.
98 Montero, 184k.
Re: New guy here with 1994 Montero SR [Re: MichaelV] #1063977 09/17/13 05:45 PM
easy to pull the instrument cluster/panel. Just a few screws. Check the FSM though on the disassembly so you don't do something stupid and mess it up somehow. <img src="/forums/images/graemlins/wink.gif" alt="" />
There's an access panel in the rear for the tank.
2H the rear wheels in the dash should be lit. If they're not then the bulbs are burnt out. The fronts should stay on when engaged and turn off when disengaged. If they're flashing then a signal is telling the unit that front wheels are engaged (although it may not be). In the gen II it uses a central axle disconnect system (CAD) versus the typical locking hubs found in the gen I's. There's a CAD actuator that may be going bad. In the FAQ post/thread there is a link to a super select system troubleshooting guide which you should review and use to help figure out what's wrong.
Thanks! We certainly try. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: New guy here with 1994 Montero SR [Re: off-roader] #1063978 09/18/13 06:54 AM
MichaelV Offline OP
Thanks for the help everyone, looks like I have some work to do!
'94 Montero SR
Re: New guy here with 1994 Montero SR [Re: MichaelV] #1063979 09/23/13 04:42 AM
mynion Offline
Good luck, have fun... Ive a 94 monty as well, had it for about a year now, fun.
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6322 MB (Peak: 0.7390 MB) Data Comp: Off Server Time: 2026-06-10 01:44:33 UTC
