looking for info and parts list or diagram of rear suspension #1064041 09/18/13 09:32 PM
I
Icentropy Offline OP
I'm trying to find the part name or number of some rubber pads that fell apart on my 1996 2WD Sportage rear springs. If i lift the car up off the rear tires the rear springs literally fall out?! is that normal? Am i missing something there? Need a diagram to see what/if i'm missing parts or something. Also i can't find any coil spring seat for the rear listed anywhere online. I only see front ones...
Re: looking for info and parts list or diagram of rear suspension [Re: Icentropy] #1064042 09/20/13 03:42 PM
homerdog Offline
Try this, it's a website for Kia parts. You do have to sign up for it.
web page
It may not work very well in Firefox so try IE
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: looking for info and parts list or diagram of rear suspension [Re: homerdog] #1064043 09/23/13 03:47 PM
Davey Offline
your shock absorbers are supposed to restrict axle travel to retain the springs, I'd check if yours are the correct items.
Missing the rubber pads wouldn't help either..
I've just had a good look thru my 98-99 service manual, and it doesn't have part numbers for anything at all <img src="/forums/images/graemlins/zombie.gif" alt="" />
Long a$$ 2000 Sporty, auto, 5.38 gears, TF front locker, 4"+ front lift (Kings +40 springs, 50mm spacers, 1.5" diff drop), TJ 104 rears 3" + 50mm coil spacers, 1.5" body lift, 31/10.5r15's on 15x8 Kings (ET-13), WARN manuals, Smart Bar, spotties
Re: looking for info and parts list or diagram of rear suspension [Re: Davey] #1064044 09/23/13 05:43 PM
homerdog Offline
Everet might have what you're looking for, if he's still around.
bump stop
2011 Kia Forte EX
Re: looking for info and parts list or diagram of rear suspension [Re: homerdog] #1064045 09/24/13 01:31 PM
Everet Offline
Bump stops I sell won't work with stock springs.
It sounds like wrong shocks or springs are collapsed.
A source for the spring pads is pick-n-pull.
Everet
Re: looking for info and parts list or diagram of rear suspension [Re: Everet] #1064046 09/27/13 08:13 PM
I
I finally figured out how to add the topic to my favorites. This whole time i figured no one was replying.... <img src="/forums/images/graemlins/baby.gif" alt="" />
Thanks for the info guys. I guess the springs must be broken or cut or something. I doubt whoever had it before put the wrong length of shocks in. I'm thinking of just buying the TJ coil springs (around $50 with shipping) and see what that does. The rubber pads used are another $30! i thought that was weird. and i can't believe they're not available new? I woulda thought for $30 i'd be buying new rubber pieces not decades old ones. Oh well.
Re: looking for info and parts list or diagram of rear suspension [Re: Icentropy] #1064047 09/27/13 10:50 PM
I
well i just ordered two Jeep TJ springs for $50 shipped, (that's the cheapest i could find) the only issue is they're 106A style and are from a jeep with only 40K miles on it. Soo now i have to figure out if that's gonna give me issues with the shocks i have (shocks which i don't know if they're even the right ones. So does anyone know what shocks would work for these springs? I read 1999 rav4 shocks work but require parts (universal adapters?) from a lift kit that i don't have, also is my car going to look or drive terribly now since i have no front lift? I'm just trying to get out of this as cheap as possible and it seems every turn requires more investment... <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: looking for info and parts list or diagram of rear suspension [Re: Icentropy] #1064048 09/30/13 05:00 PM
homerdog Offline
The 106's will give you about 4 inches of lift on the rear. I can't tell you about driveability because I did everything all at once. Front lift, rear springs. The bilsteins from a rav4 will fit. I don't think there's any modifications necessary, just a tight fit over the bolts that hold them on.
2011 Kia Forte EX
Re: looking for info and parts list or diagram of rear suspension [Re: homerdog] #1064049 09/30/13 05:28 PM
I
So regular Rav4 shocks work without any extra parts? I saw on upyourkia.com and on another post that using rav4 shocks required some adapter of some kind?
Re: looking for info and parts list or diagram of rear suspension [Re: Icentropy] #1064050 09/30/13 06:08 PM
jaybrian32 Offline
You just need to reuse the steel bushing from the bottom of your stock shocks in the new Rav4 shocks, as these don't come with the steel insert that goes inside the rubber bushing in the bottom shock mount, you will also need to spread the bottom mount on the axle to accept the large Rav4 bottom mount.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6340 MB (Peak: 0.7425 MB) Data Comp: Off Server Time: 2026-10-24 03:23:05 UTC
