fpr with a weber? #1064263 09/26/13 01:00 PM
SledgeHammer Offline OP
Do you need to run a fpr with a weber carb?
The monty I picked up is a slow pig and just doesn't want to run smoothly,esp in accelerating.If you give it gas,it is feeling choked up but if you back off some,it runs ok.
we had a mighty max 4x4 last year that ran horrible and installed a fpr and diealed in the correct pressure and it woke up and ran perfectly.
1991 Montero RS
Re: fpr with a weber? [Re: SledgeHammer] #1064264 09/26/13 05:12 PM
geocrasher Offline
Stock fuel pressure is about 7lbs, weber requires no more than 2lbs, or even 1.5. There are folks here who run without a fpr, but when I do the weber conversion, I'll be using a fpr.
And I just have to add: "Trust me, I know what I'm doing." <booooom>
http://tidbitsfortechs.com/
Re: fpr with a weber? [Re: geocrasher] #1064265 09/26/13 10:55 PM
Thanks,i do believe I will add a fpr to it.it just dies going up hills and sputters.3rd and 4th gear or rough till I pass that certain rpm then it will kinda pick back up.
1991 Montero RS
Re: fpr with a weber? [Re: SledgeHammer] #1064266 10/02/13 05:19 PM
here is what the monty does with NO FPR installed:
1st gear...pulls fine
2nd gear,if I give it to much pedal,it breaks up,half throttle it will pull ok
3rd gear,same thing as 2nd.
4th,will pull fine,doesn't sputter but feels like it's not wuite there yet.
5th gear will zoom along,but going up hill,even slightly,i feel the sputter coming along and have to drop back to 4th.
with fpr...I went thru ever psi starting with 1lb,it is un driveable...breaks up with the pedal p[ressed,if I give it half throttle,it runs fine but it can't pull a hill.
1991 Montero RS
Re: fpr with a weber? [Re: SledgeHammer] #1064267 10/03/13 07:30 AM
geocrasher Offline
Well, I'm certainly no carb expert but what you're describing sound to me like a great reason for a rebuild and a thorough cleaning.
Re: fpr with a weber? [Re: geocrasher] #1064268 10/03/13 05:11 PM
rebuild a new carb?
1991 Montero RS
Re: fpr with a weber? [Re: SledgeHammer] #1064269 10/03/13 07:03 PM
geocrasher Offline
I knew the truck was new to you, but I did not realize the carb was brand new. They typically don't run that badly even if they need tuning. Have you checked timing etc?
Re: fpr with a weber? [Re: geocrasher] #1064270 10/03/13 07:46 PM
yeah,carb is about 6 months old,i would hope a rebuild isn't needed so soon.
Timing is something I need to check.
I did drive it day before last...with no fpr....and it drove lik I described above.I stopped at a store,got a drink,and took off and it ran perfectly.No spitting/sputtering ad it pulled a hill like it should.Ran like this for about 20 minutes then went back to the cutting out issues.
1991 Montero RS
Re: fpr with a weber? [Re: SledgeHammer] #1064271 10/04/13 04:19 PM
ryany Offline
Check the float system inside the carb - it sounds like it's running out of gas. You may have a needle valve that's sticking or an incorrect float level setting. There's also possibly some debris floating around in your float bowl that could be intermittently clogging a jet. Do you have a quality fuel filter on it that's been replaced recently?
I don't think you should need a FPR with the stock fuel pump, it's designed for a carburetor and shouldn't be able to overpower the float valve in your Weber.
95 Montero SR
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6289 MB (Peak: 0.7333 MB) Data Comp: Off Server Time: 2026-07-14 10:41:32 UTC
