Motor Mount part numbers #1064288 09/26/13 11:07 PM
matseel Offline OP
Hello everyone,
I'm pressed for time. Does anyone know the part numbers for the motor mounts for Gen 2 below? *Update MR132720 [front] All the rubber bushings are falling apart from age etc. Well else do you recommend changing? I'm not mechanically inclined. Im ordering new transmission mounts MB951304
Just completed severe service with new plenum, radiator,water pump, timing belt, spark plugs, hoses, belts, both front drive axles, bearings, transmission, both diffs, transfer case, new tires, etc etc..thanks as always. Keep smiling!
cheers,
matseel
1994 Montero SR 3.5 DOHC, Safari Snorkel, Diehard Platinum,
OME suspension, factory rear locker, rear sway bar removed, Cobra 75 WX ST, 33" BFG KM2
New Mexico Land of Enchantment
Re: Motor Mount part numbers [Re: matseel] #1064289 09/27/13 04:14 AM
mxmikie Offline
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5909 MB (Peak: 0.6392 MB) Data Comp: Off Server Time: 2026-05-25 14:59:48 UTC
