My new (to me) 1995 Montero SR #1064290 09/28/13 04:49 PM
Stumpy Offline OP
I just bought a Montero and have a couple of questions. The engine runs great and the body is rust free. A real oddity around here. The first thing I noticed on the drive home is that it will not shift into overdrive. The light will toggle on and off but no o/d. It also will not downshift when you hit the accelerator and the cruise does not work. No cruise light when you hit the set button. I changed the thermostat and the temp gauge does work. Any ideas where I should go from here? Thanks, John.
Re: My new (to me) 1995 Montero SR [Re: Stumpy] #1064291 09/28/13 06:13 PM
L
Lesharoturbo Offline
The not going into overdrive and not downshifting may be as simple as adjusting the kickdown cable. When I got mine in 2006 (1994 model), the seller had tried to clean the engine up and pulled the kickdown cable out of the metal ferrule at the intake. It would not shift into OD until you mash ed gas to the floor and released while on a flat road.
94 LS 3.0
Re: My new (to me) 1995 Montero SR [Re: Stumpy] #1064292 09/28/13 06:36 PM
Stumpy Offline OP
The thermostat I put in was rated at 180. I seen in the owners manual it requires a 190. Would that cause it to not go into overdrive?
Re: My new (to me) 1995 Montero SR [Re: Stumpy] #1064293 09/29/13 01:29 AM
L
Probably not as mine is 182 degrees. I do not think that opening the thermostat sooner would cause it not to go into OD. I do think the cable needs a look. Although, mine is an LS with the 3.0 so yours may have a different downshift mechanism.
94 LS 3.0
Re: My new (to me) 1995 Montero SR [Re: Stumpy] #1064294 09/29/13 05:22 AM
TrailRaider Offline
There is also a separate temp sensor used by the trans computer to monitor engine temp. 1 of the many on the water neck. Make sure all those are working properly. As a primary, would suspect the kickdown cable as mentioned previously first though.
'89 Raider V6 auto.
Re: My new (to me) 1995 Montero SR [Re: TrailRaider] #1064295 09/30/13 01:58 AM
Stumpy Offline OP
The kickdown cable appears to be adjusted correctly. At full throttle, there is no play. I did find another temp sensor in the neck of the water inlet above the thermostat. It is a two wire sensor and do not show any of the auto parts show stocking it online. I will check with the factory tomorrow.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6090 MB (Peak: 0.6788 MB) Data Comp: Off Server Time: 2026-06-21 13:41:30 UTC
