5 speed auto vs 4 speed auto #1064317 09/29/13 03:50 PM
L
Lesharoturbo Offline OP
Does anyone know if the trans ecu is compatible? Are the 2 transmissions interchangeable? I do know the top gear ratio is the same and basically the 5 speed gives you more middle ratios as compared to the 4 speed. However, it may be a better mate for the 3.0 than the 4 speed.
Just thinking out loud.
94 LS 3.0
Re: 5 speed auto vs 4 speed auto [Re: Lesharoturbo] #1064318 09/29/13 05:40 PM
Non interchangeable ECU, you'd also need a body lift to clear the bigger transmission. Not sure if the different transfer cases bolt up
Re: 5 speed auto vs 4 speed auto [Re: TOASTY] #1064319 09/30/13 01:49 PM
L
I was not expecting a body lift. Is there a lift n the Gen2 3.5 with the 5-speed over a Gen 2 3.0 with the 4-speed? I have never seen them side by side to compare.
I just moved to Texas and these rigs are pretty rare around here.
94 LS 3.0
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5923 MB (Peak: 0.6456 MB) Data Comp: Off Server Time: 2026-07-17 02:20:16 UTC
