Help! Speedometer and tach not working! #1064653 10/06/13 02:23 AM
94Monty Offline OP
My Speedometer stopped working today. Any clues where I should look. My tachometer stopped working about a month ago. At first I thought it was no big deal. But now I want them both back. Checked all my fuses, they were fine. Where else should I look?
94SR 3.5L(AT)factory rear locker 31/10.5R15 BFG M/T
94LS 3.0L(M)30/9.5R15 Falken Wild Peaks
2003 Limited(AT) BFG A/T
Re: Help! Speedometer and tach not working! [Re: 94Monty] #1064654 10/06/13 05:05 AM
Which truck?
Re: Help! Speedometer and tach not working! [Re: fasteddy] #1064655 10/06/13 07:03 PM
94Monty Offline OP
Sorry, I guess I should have mentioned that. It's on the 94SR Monty. I did a search to see what others have said about this topic, and will be pulling the instrument cluster and looking for burnt connections.
Re: Help! Speedometer and tach not working! [Re: 94Monty] #1064656 10/07/13 12:40 AM
Looking at the circuit diagram, nothing in common but fuse 11, and that would kill some other stuff, I think. I'd cycle the cluster connectors and check the board.
Re: Help! Speedometer and tach not working! [Re: fasteddy] #1064657 10/08/13 05:20 AM
94Monty Offline OP
Turns out it was the circuitry on the back of the Speedometer, just like PanamaMike00 and Ataki!
Now my Speedometer and Tachometer work. The tach is still intermittent. but at least the speedometer and odometer work.
Here are some pictures of the repair. The broken ribbon wire at the end off yellow arrow.
I used a pencil eraser to removed the coating on the wire ribbons. Then I used a knife point to expose extra ribbon to land solder on.
Soldered the jumper wire in place.
Applied Plasty Dip to recover the exposed wire ribbon.
Re: Help! Speedometer and tach not working! [Re: fasteddy] #1064658 10/08/13 05:24 AM
94Monty Offline OP
Hope this helps. Thanks for the reply "fasteddy"
This form is awesome!
Re: Help! Speedometer and tach not working! [Re: 94Monty] #1064659 10/08/13 05:44 AM
Thanks to the many contributors that solve the many problems? I think we have all needed this help from time to time, and we all appreciate hearing positive feedback!
Re: Help! Speedometer and tach not working! [Re: rxinhed] #1064660 10/08/13 06:17 AM
Good on ye for fixing it. Note, the pro method of repair is to drill two holes on each side of the break and solder in a wire jumper, but yours worked.
Re the tach, download the fsm from mitsubishilinks.com and trace the wiring from the coil pack, paying attention to the LC filter in the circuit.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6281 MB (Peak: 0.7233 MB) Data Comp: Off Server Time: 2026-05-29 16:03:59 UTC
