SWB 87 Montero Engine Swap to 5.0 fuel injected #1065255 10/24/13 03:13 PM
F
federico Offline OP
Any problems that should arise??
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: federico] #1065256 10/24/13 03:42 PM
Struc Offline
Not enough info to weigh in. Tell us about your plans for the swap, including all drivetrain info.
Curt Shambeau
87 Mitsubishi Montero SWB (Turbo G64b wideblock conversion soon)
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected *DELETED* [Re: Struc] #1065257 10/24/13 05:03 PM
F
federico Offline OP
Post deleted by federico
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: federico] #1065258 10/25/13 02:00 AM
Something wrong with your pics. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: rxinhed] #1065259 10/25/13 09:37 AM
F
federico Offline OP
Hope this one works
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: federico] #1065260 10/25/13 09:41 AM
F
federico Offline OP
So I have an 89 5.0 mustang engine with the wiring harness so I can have it fuel injected plan to use an early bronco tcase and trans and swap rear ends have a 9 inch rear end..
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: federico] #1065261 10/25/13 03:45 PM
geocrasher Offline
Thats a good looking rig. Is it a 4cyl or V6? You might not need to swap in a 9" rear end. You could get a SR rear end with a locker in it and it would be strong enough, have disk brakes, bolt right in, and match the front ratio. Of course, if you already have the 9" and have a 4.56 third for it, then you're good to go in that regard.
Now, if your truck is a 4cyl, and in reasonable condition, lemme know. I might be eying some of your leftovers ;-)
http://tidbitsfortechs.com/
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: geocrasher] #1065262 10/25/13 05:28 PM
Note the rear leaf springs. It's a 4-cyl.
OP, what are your plans for fueling? It's going to need an electric pump.
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: JohnnyBfromPeoria] #1065263 10/25/13 07:13 PM
F
federico Offline OP
I have 2 and 88 auto 4 cyl and 87 manual 4 cyl.. planning to even remove the complete top and convertibalize the black one and put a roll cage... Would the current suspension hold a v8? I would like to go crazy with this project and keep my other one stock since its an automatic.
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: JohnnyBfromPeoria] #1065264 10/25/13 08:12 PM
F
federico Offline OP
As far as fueling I will go electric.
PHP: 7.4.33 Page Time: 0.007s Queries: 17 (0.005s) Memory: 0.6386 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-06-17 10:32:37 UTC
