Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: JohnnyBfromPeoria] #1065265 10/25/13 09:48 PM
geocrasher Offline
Note the rear leaf springs. It's a 4-cyl.
For some reason I thought the SWB's were all leaf sprung, but the V6's got coils too then.
Federico, what part of WA are you in?
http://tidbitsfortechs.com/
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: geocrasher] #1065266 10/26/13 12:16 AM
F
federico Offline OP
Central Wa... Has anyone here made a convert out of one? This gent wss in the process of converting it to a truck
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: federico] #1065267 10/26/13 03:05 AM
Called the J-top...
You could run a carb and do less work. To clear the Ford trans, you'll need a body lift or reworking the tunnel cover.
Also, here is another thread on this topic:
4x4Wire thread
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: rxinhed] #1065268 10/26/13 07:16 AM
F
federico Offline OP
That rig looks so.cool... It would be easier to.run a carb too... Ok so can I use the same tranny and figure out a way to pair the engine and stick tranny together?? Plan to make lots of measurements tmanana..
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: federico] #1065269 10/26/13 05:04 PM
justice Offline
There was a dude that put a mustang 5.0 FI motor in an 87/88 SWB about 15-20 years back, so yes its possible. He ran it for a while then put it into storage and sorta disappeared so not a lot of info exists other than we know he did it and posted pics that have since gone away.
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: justice] #1065270 10/26/13 05:38 PM
Link to that 2007 thread is hyperlinked above.
Re: SWB 87 Montero Engine Swap to 5.0 fuel injected [Re: rxinhed] #1065271 10/27/13 03:34 AM
Those jumpseats are too cool. I have a set from a Ranger that I want to fit in some day.
PHP: 7.4.33 Page Time: 0.006s Queries: 17 (0.004s) Memory: 0.6257 MB (Peak: 0.7325 MB) Data Comp: Off Server Time: 2026-06-17 10:44:32 UTC
